300D50 wrote:
Are you still using the stock PCM from the 13B-MSP? Last I knew my 04 had cruise/iac/DSC-TC integrated in the main PCM, but I'll be honest and say I haven't looked at the wiring diagrams in-depth yet.
The RX8 ECU drives the canbus cluster (tach, gauges, lights), the fuel pump, the radiator fans, and the climate control (AC relay). I'm using the RX8's drive-by-wire throttle body. To keep the RX8 ECU out of limp mode, the oil metering pump has to be connected and tucked away, and the ECU needs to see a CAS signal. That's all. The DBW throttle also controls the engine's idle. Cruise and traction control should work as well. To test the theory, I created the waveform of the RX8 CAS in an audio editing program then connected my laptop's headphone output to the RX8 CAS input. And had a little fun sequencing a song...
https://www.youtube.com/watch?v=R1xj_gbQA58The Isuzu ECU uses the Isuzu crank and cam sensors. It controls fuel, ignition, and emission control systems (OBDII). The OBDII signal from this ECU is wired to the 8's OBDII port.
An AEM FIC piggy-back ECU will be wired into the Isuzu ECU to manage the larger injectors and lock the O2s when under boost conditions.
