kaistallings wrote:
Thanks for the info, once again! I would like to contribute to your project somehow for providing so much info, seriously -- even though I'll likely be using a direct bolt-on transmission option myself, maybe you'll let me cover the cost of your custom pilot spacer in exchange for those STEP files?
Anything helps.
If your using the Isuzu AR5 you won't need it. Just run all the stock components from a manual 98+ RWD Trooper and your good to go. Finding it may be the hard part.
Screw that Rally Fighter. The Nomad on the other hand is 110% bad ass. Since that vehicle is fairly short, you may like the placement of the Trooper AR5's shifter location. Don't discount the MAU5 too much. It's not that bad of transmission. They shift rather well actually. If your going NA or even mildly boosted it'll still hold up. Remember. Your not pushing a 4000lb Rodeo for 250k miles either. Your pushing 1500lbs. It's just going to roach tires. IF you find your popping the MAU5, the Trooper AR5 would be a bolt-in replacement at that point.
Should you find a 2WD Trooper hard to find, look into the '90s 4 cylinder Dodge Dakota. It has the AR5 pattern on one side and a GM60 in the other. It might work but I haven't verified. A friend of mine is using the Dakota bellhousing to bolt a Solstice MA5 to his 3800 v6 that he's using for his RX8 swap. I'll test fit it on my engine as soon as it's off the stand but it should bolt up. I have no idea what trans the Dakota used. Probably an AR5 or AX15. Options options options! What's not to love about this engine?!
