It is currently April 16, 2024, 2:18 pm
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: December 8, 2014, 9:56 pm
Im really considering this engine now for my build verse the R1. Fix alot of the issues I am having with using an R1. I drew a quick model in sketchup. If anyone needs it let me know and Ill upload it.
Throw up some dimensions of the trans when you get it too so I can draw it as well.
Thanks!!
Oh, and that engine sounds really good in that video. Almost like its supercharged and not turbo'd.
PostPosted: December 9, 2014, 8:48 am
Some of the sound might also be transmission or other drivetrain also. Still cool little motor.
Link to my build log:
PostPosted: December 10, 2014, 12:08 am
True, I know straight cut dog type gears whine quite loud.
PostPosted: December 10, 2014, 10:12 pm
Could I get some measurements of the oil pan? Just wanting to get part as close as I can in the drawing.
Possibly the engine mount locations too?
PostPosted: December 11, 2014, 12:26 am
Does the RWD transmission from the Sky/Solstice not also fit this motor?
PostPosted: December 11, 2014, 12:53 pm
I might get more measurements for you on the oil pan and T-5 this weekend.
PostPosted: December 11, 2014, 12:57 pm
Not sure. If the 2.0L Ecotec has the pattern on the block as the Ecotec 1.4T motor or close like the 2.2L 4cyl motor used in the Isuzu then yes. I don't know how to find this info. Maybe an Ecotec Forum?
PostPosted: December 11, 2014, 9:57 pm
The Gm transmission just seems like a simpler solution, should it fit. Probably more clutch and pressure plate options down the road too.
I don't know that it's any better, but one day it might be easier to buy or fix things.
PostPosted: December 12, 2014, 12:08 pm
What are the gear ratios for the T-5 trans? Trying to figure out if my suby rear end is a good choice. Thanks!!
PostPosted: December 13, 2014, 1:28 pm
The T5 was (is) used my multiple makers here and abroad. Here's the low-down on the Mustang variants. It should be pretty close no matter where you source your T5, but there might be differences too.
Mustang T5 history/ratios (ratios in table) ==> http://www.allfordmustangs.com/Detailed/349.shtml
Lonnie
PostPosted: December 13, 2014, 10:44 pm
Thanks Lonnie!!
PostPosted: December 16, 2014, 10:44 pm
Yes the Isuzu bell housing bolts right up. All holes in the block line up perfectly. The oil pan bolts do not. Not sure if this is an issue. I can drill and tap two additional if necessary in the oi pan flange. I will also have to fab some covers for the gaps to keep the crud out of the clutch area.
PostPosted: December 16, 2014, 10:58 pm
Dimensions for those modeling this.
PostPosted: December 25, 2014, 9:49 am
Thanks for sharing, I'll be following this very closely.
PostPosted: December 25, 2014, 11:30 am
JMO but if I could get all the cast iron bolted up I would skip the pan. And then just build the cover for the gap.
Looks good. It makes me think of pulling my 5.0 and go 4 cylinder ? :cheers:
American 7 5.0 T5
Lotus 15 ish?
914/H6
