It is currently February 23, 2019, 7:33 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
 Post subject: Donor info database
PostPosted: January 24, 2007, 8:17 pm
This is a work in progress and far from complete. If you have info you want to add, just post it here and we'll add it to the appropriate file.
Thanks!
Compliments of Nkeehn:
Transmissions:
http://www.locostusa.com/files/Trans%20Data.xls
Engines:
http://www.locostusa.com/files/Engine%20Chart.xls
Compliments of DarthV8r
Rear ends:
http://fxide.ca/content/projects/locost ... nsions.xls
PostPosted: January 24, 2007, 9:46 pm
If anyone wants rear end width numbers added to the spreadsheet above just PM me the info.
Some additional stuff here, not all Locost relevant:
Axle Widths:
http://moose.ca/axle_widths
Five Bolt Wheel Donors:
http://moose.ca/five_bolt
Wheel Weights (tires not likely on a Locost ;)
http://moose.ca/node/47
Transmission Tables:
http://moose.ca/node/43
http://moose.ca/node/28
Transfer Cases:
http://moose.ca/node/46
How to Identify a Dana Axle:
http://moose.ca/node/42
Borg-Warner T-5 Transmission Identification Numbers
http://moose.ca/t5_id
Admins, feel free to merge these links into the original post and delete this post for the sake of aesthetics. ;)
PostPosted: January 25, 2007, 2:43 am
Further engine info. http://www.bacomatic.org/~dw/txt/engfyi.htm
Lots of other good info. http://www.bacomatic.org/~dw/index.htm
PostPosted: December 6, 2007, 6:04 pm
An interesting link with some engine weights ....
http://forums.hybridz.org/showthread.php?t=125246
L-24, 389.4 lbs. (datsun 240z)
VG30DETT, 469.8 lbs
Same engine MINUS the turbos, 442.2 lbs
2003 GM Vortec 5.3 w/4L60E, 779.4 lbs.
2002 LS6 w/4L60E, 609.0 lbs
Suby EJ22, 214.8 lbs.
read the link for pictures and specifics...
I'll keep an eye out for you!
To err is human...
I am more human than most.
PostPosted: April 9, 2008, 9:46 am
This does seem to come in at a very reasonable weight. Looks like no
flywheel in the pictures and their is no weight posted for it or clutch, unless it was included in the transmission weight.
Duratec 2.0 info from Mark Conley:
http://autos.groups.yahoo.com/group/Locost_North_America/message/41865
Mark Conley:
I pulled most things off and weighed them separately:
engine 192lbs
exhaust (and cat) 20lbs
belt tensioner 26oz
injector rail and injectors 27 oz
power steering pump 120oz
egr valve 13oz
alternator 12lbs
intake (no throttle body and partly broken) 101oz
engine harness (cut at firewall) 45oz
coolant hoses (that I have) 45oz
Some dimensions:
Length from flywheel to front pulley (no flywheel, to end of crank) 19.5"
Width at widest part of block (Where Tranny mounts) 14.5"
Width at widest part of head (At front) 11" (general width) 8.5"
Width including stock manifolds (exhaust not usable) +8" for stock intake.
Height from cam cover to bottom of block (tall side)19" (short side)
18.25"
Note: height of coil on plugs in pictures from above link.
Height overall (from bottom of sump to cam cover) 24"
Length of gearbox from bellhousing to tailshaft 32"
Width of bellhousing 14.5"
Length of bellhousing (at top) 6.5"
Note: see pictures, bell housing tapers to different lengths on sides.
Height of bellhousing 14.25"
Taper of bellhousing Not sure how to get, look at pictues.
Width of gearbox case 8"
Length of gearbox case 10.5"
Height of gearbox case 10.5"
Length of tailshaft 12" (includes 5/6 gear casing)
Weight of gearbox (dry) 101 lbs
Weight of bellhousing (if removable) N/A
PostPosted: April 9, 2008, 2:47 pm
Two more data points.
From KB58:
My brother just weighed his L67 supercharged V6 - 430lbs minus the alternator, so figure 445-450 for the complete engine.
The transmission weighs 100lbs even, including the clutch and pressure plate.
From William's Racing:
Cosworth BDA complete with carbs, flywheel, clutch is a hair over 200 lbs., 200+ HP.
The BDA is built on an xflow bottom end and the xflows now have aluminum heads so they should also come in at a similar weight.
PostPosted: April 9, 2008, 3:08 pm
H22A1, complete with alt, starter, intake, upper exhaust, and stock transaxle, 475 lbs.
Honda K24 series is alledged to be similiar, will post after I weigh mine.
PostPosted: April 9, 2008, 8:44 pm
Source: posted by jlicrx on hondaswap.com
88-91 CRX/Civic engine weights:
CRX HF D15B6 - 195lbs (dry)
CRX/Civic DX D15B2 - 208lbs (dry)
CRX/Civic Si D16A6 - 219lbs (dry)
JDM DOHC ZC - 232lbs (dry)
JDM B16A - 309lbs (wet)
88-91 CRX/Civic L3 D-series transmission - 63lbs
__________________
ZCspeed Racing
PostPosted: April 9, 2008, 9:07 pm
Source: Sands Museum
Rover K-series:
1.4L 16V ......... 287 lbs (includes transaxle)
1.8L 16V ......... 212 lbs (dressed: incl. manifolds, clutch, fluids)
Honda S2000
2.0L 16V ......... 348 lbs (dressed: incl. manifolds, clutch, fluids)
Toyota (Lotus Elise installation)
1.9L VVT ........ 304 lbs (dressed: incl. manifolds, clutch, fluids)
PostPosted: April 9, 2008, 9:42 pm
Hmmm...
Honda B18C (VTEC)
Block ... 67 lbs
Head ... 38 lbs (loaded: valves, springs, cams, etc.)
Rods ..... 5 lbs
Pistons... 2 lbs
Crank .. 33 lbs
Total ... 145 lbs for "longblock"
Observation: The factory "externals" (flywheel, manifolds, cam cover, oil pan, water pump, etc.) must weigh ~160-170 lbs ... that's more than the longblock!
Ford 302 V8 (i.e. 5.0)
Block ... 83 lbs (ALUMINUM)
Heads .. 46 lbs (Aluminum... pair, loaded: valves, springs, etc.)
Cam .... 11 lbs (incl. lifters, pushrods)
Rods .... 11 lbs
Pistons... 8 lbs .. (corrected)
Crank .. 48 lbs
Total ... 207 lbs for "longblock"
Observation: Too bad Ford never made the aluminum block for the low-deck SBF... Dart aluminum block costs $4,900. Careful selection of externals (fabbed sheet manifold and oil pan, aluminum flywheel, etc.) could yield that mythical "under 300 lbs V8"... with 43% more displacement and much better heads than the Buick/Olds/Rover 3500. Certainly would be a Seven Supercar. 8)
Last edited by SportsCarDesigner on April 10, 2008, 1:51 am, edited 1 time in total.
 Post subject: 2000 Yamaha R1
PostPosted: April 9, 2008, 11:19 pm
Complete (engine, gearbox, starter and harness)
182lbs
(via bathroom scale, so it's not legal for tender)
PostPosted: April 10, 2008, 12:09 am
Honda H22:
Shortblock ... 123 lbs. (shown on scale)
Head ............. 48 lbs. ("10 lbs heavier than B16")
Total ........... 171 lbs. "longblock"
H transaxle ... 96 lbs.
B transaxle ... 90 lbs.
Observation: Again, the factory externals weigh as much or more than the longblock (based on Kurt's 475 lbs total).
(B16 shortblock on scale 104 lbs... D16 Shortblock (+oil pan) on scale 100 lbs)
PostPosted: April 10, 2008, 12:26 am
SportsCarDesigner - Clearly you forgot the wrist pins!
Geez, for a day I thought we made some progress. Those numbers are so light - I'm just confused again.
I went downstairs and grabbed a connecting rod/piston from my old FF engine. It weighs 2.75 lbs on my kitchen scale, probably pretty accurate ( actualy 2 lbs, 11 and 3/4 ounces )
This is for a 1600 cc motor, so the rods for that Ford 302 sound very light. I think the rods in the xflow motor are well regarded...
Sigh... I'm afraid the brain hurting stage of this Locost build is going to take a lot longer then I thought.
 Post subject: Re: 2000 Yamaha R1
PostPosted: April 10, 2008, 1:16 am
182lbs
Holy crap! I knew bike engines were lighter than car engines but dang.
PostPosted: April 10, 2008, 1:37 am
Yup (if the scale is right). And you can get a chain driven LSD for 12 lbs!
