Ok so background. I started experiencing this a month or 2 ago. Basically after driving for a while and then finding myself in stop and go traffic I noticed that when I have the clutch engaged with no throttle the idle would start to pulse. So today I set out to reproduce this issue.
Car details:
Lotus 7 powered by 1.6 miata
M45 Supercharger
MSPNP2
Wilwood Pedals - Clutch switch has been bypassed via attaching the 2 wires together.
All the idle warm-up parts have been removed from throttle body and intake manifold.
Other notes not shown in video below - On occasion when doing this it seems a cylinder will stop firing. Not sure if this is related or not. But this is even harder to reproduce, and will start working again as soon as I give it some gas.
So here are the details of the test:
I started the car, with just the key no clutch. Then let is warm up till the fan kicked in. Then I hopped in the car and pressed the clutch, this sent the idle pulsing. Released clutch and it stopped. Pressed Clutch it pulsed. ETC. Finally I blipped the throttle and it went away. See video here:
http://youtu.be/5_VESPXs-wcSo anyone have any ideas? Best guess right now is the neutral switch, but don't have an understanding on how that could be causing this issue and why the clutch would play into it, when they is no signal being sent for it.
Up to date build information can be found here:
https://allthingsspeed.com/projects/
