oh , i may be calculating my stuff wrong then , i thought the FD of the bike transmission was the actual front and rear sprokets with the chain . even with a Miata 4.3 diff the end speeds were off the roof .
on the chart below i was comparing a VW trans and the GSXR tranny gears applied to a car diff without knowing about the actual final drive of the gsxr... this explains some stuff...
This is to be put into an old Beetle wich is about 1000lbs with the engine removed , i want it to be snappy
I do have a 02J transmission and another VW cable trans in the garage that i could tear apart
so how do you guys calculate all the reductions combined then ?
here is what my data looked like
http://www.teammfactory.com/gearcalcula ... on+1+%26+2So now with the added reduction the maths are getting way more plausible
10k rpm with 3.89 diff and 1.55 reduction , now may be a bit too short for highway use
1st : 70kmh
2nd :92kmh
3rd :112kmh
4th :130kmh
5th :145kmh
6th :157kmh
Thanks for your answers , this project is very exciting
