It is currently April 17, 2024, 10:00 pm
 Post subject: Nissan ka24de
PostPosted: January 9, 2018, 12:00 pm
Hi
I'm thinking install a Nissan ka24de in a locost 442, but when I try to lift up
was hard to do. I need a tip from the gurus in this forum ....is this a good engine
with bike carby's and some different cams and headers, or is too heavy and weak ?
You know how much weight it ?
Thanks in advance
Felipe
 Post subject: Re: Nissan ka24de
PostPosted: January 11, 2018, 12:56 am
I'm not a Nissan expert but from the 240s I've seen kicking around I have no doubt a locost powered by the similar motor would be more than adequate.
If you already own it and you know it runs that sounds like a great donor engine to me. Might be a bit tall of an engine but lots of folks find a way to deal with that.
Weight? Lol I'm putting a cast iron v8 in mine so you've got nothing to worry about as far as this thing moving.
PostPosted: January 11, 2018, 10:56 am
You might want to take a look at this thread! http://www.locostusa.com/forums/viewtopic.php?f=4&t=14453&hilit=ka24de
Good Luck! :cheers:
PostPosted: January 11, 2018, 11:43 am
A ka24de is an undersquare motor 89mm bore X 96mm stroke, no balance shafts, 3 valves per cylinder.
An upgrade to the L family motors with a crossflow head keeping the chain driven single cam early (DOHC 91 up).
However it is best to get a car version as they have a crank girdle, the truck motors don't have one.
I would leave the cams alone and add a turbo kit if you want more power.
I would port inject it with an MegaSquirt controller.
Downside is it's going to shake a bit & taller, upside is great gobbs of torque and RWD friendly.
A square motor or over-square motor will shake less but you have to rev them up to get the torque.
Do you have a KD24DE? Or are you shopping the idea?
Honey anyone?
