Summary of engine weights
Potential donor discussions and troubleshooting, gas, diesel, electric powered builds etc..
chrisrobertson
Post by chrisrobertson »
I'm kicking around the idea of building a mid-engine similar to Kimini, La Bala, etc and been trying to track down a light motor. So that others don't have to do the same amount of research here's what I've been able to find.
Note I didn't actually weigh any of these so don't rely on the accuracy! If anyone has any other engine weights to add fire away!
Honda
D = 100lb short block + oil pan (110-130 hp)
B = 104lb short block only (160-190 hp)
H = 123lb short black only (160-215 hp)
H trans = 96lb
D trans = 90lb
Ford/Mazda (Duratec)
2.3L = 260lb w/manifolds, AC, starter, etc
215lb just the engine
Nissan
SR20DET = 490lb complete
Just engine
A12 87 kg
A14/A15 93 kg
CA18DE 113 kg
CA16 113 kg
L16 113 kg
L18 118 kg
CA18ET 118 kg
CA18DET 128 kg
L18SSS 133 kg
L20B 137 kg
SR20DE 139 kg
FJ20E 144 kg
SR20DET 149 kg
FJ20ET 166 kg
VW/Audi
260 hp S3 engine weight 335 pounds
3.2L VR6 = 373 (255hp)
3.6L VR6 FSI < 2.8L VR6
1.8T ~80lb < 2.8L VR6
BMW
X5 3.0L = 355lb
Toyota
2ZZ-GE = 115kg (as in the Elise)
2ZZ-GE Engine 64 pounds
C64 Transmission 13 pounds
Air Conditioning 22 pounds
Twin Oil coolers 29 pounds
Other modifications 26 pounds
Subaru
2.2L NA = 130kg
2.0L Turbo = 150kg
3.0L 6 cylinder = 169kg (2000-2003), 160kg (2003+)
3.2L 6 cylinder = 180kg
VW type IV (as in the Porsche 914)
2.0L = 130kg
chrisrobertson
A couple of additional Nissan engines
RB25DET - 720lbs - sport compact car magazine Sept 2003 (complete swap for a 240sx)
VQ35 - 260lbs longblock, no intake manifold (weight on bathroom scale so probably lighter than reality)
VQ35 - 313lb longblock + intake manifolds (on a fairly accurate shipping scale)
VQ30 - 127lb shortblock
VQ30 - 315lb longblock
Fester
Post by Fester »
Nice list!
The lightest engine on the list is the one I was already thinking of using. That clinches it for me.
KB58
Building: Midlana
Contact:
Post by KB58 »
(Entire here means engine, transaxle, and all accessaries needed for a Locost, meaning alternator only.)
Entire Honda H22A1 drivetrain, 460 lbs
Entire Honda K24A2 drivetrain, 405 lbs
Who drives shortblocks, anyway? :wink:
Hasbro
Post by Hasbro »
This has some weights and makes for a good read:
http://archive.grassrootsmotorsports.co ... =34472&p=1
Philippe
Re: Summary of engine weights
Post by Philippe »
In my experience reliable figures are hard to find. The main problem is that various yardsticks are being used. Short blocks, long blocks, running engines, engines with transmission , drive shaft, live axle, or IRS, engines with transaxles, engines with turbos and intercoolers. And if this was not bad enough the power output is represented in various ways too. American yardstick, European yardstick, HP at the flywheel, HP at the wheels.
My general impression is that transaxles have the power/weight ratio edge and DOHCs offer better performance enhancement possibilities. But of course I could be wrong.
IMHO the only two classes of car engines which would stand out are Mazda rotary and highly tuned aircooled Porsche-VW engines. For anything else the norm for a complete drivetrain seems to be somewhere between 350- 500 lbs.
Philippe
bremms
Building: Volvo based seven
Post by bremms »
Volvo B18/B20 330lbs with flywheel & manifolds no starter or alt.
Volvo B230 320lbs same. weighed a Alfa 2l came to 225# no flywheel
with intake manifold.
weighed a b13 rotary and it was around 220lbs can't remember if the flywheel was attached or not.
Volvo 240/P1800 Based Locost
2004 Aprilia Mille Factory
2002 Toyota Tacoma
1999 BMW M3
Driven5
Post by Driven5 »
People need to do more weight measurements like this...Unfortunately they're still not all of the same completeness for a truely direct comparison and you are not able see everything that is/isn't included on the engine. I believe the 4 banger without an engine note is a KA24DE.
gtivr4
Post by gtivr4 »
Here is an alternate weight on the KA24DE:
http://forums.nicoclub.com/zerothread/299880
371lbs
KB58
Building: Midlana
Contact:
Post by KB58 »
When comparing drivetrains, the engine, tranny, axles, and diff all have to be included. There's a fair difference between:
1. Front engine = 300lbs, tranny = 100lbs, driveshaft = 20lbs, rear axle with diff = 100lbs, for a total of 520lbs.
and:
2. Transverse engine = 300lbs, transaxle = 100lbs, for a total of 400lbs for the same power.
horizenjob
Post by horizenjob »
It is reasonable to compare weights of the components of a drive train. Particularly if you have settled on a seven-type Locost.
Saving 100-120 pounds is a worthwhile goal, but clearly there is a great deal more design work to create your car from scratch as opposed to doing a "book"design. If your goal is a seven-type car, a mid engine is probably a difficult route. Maybe in a few years it won't be. Not everyone needs to be a trailblazer.
On thread comment:
I like the old Ford crossflows. They are several inches smaller (4"?) than the other motors being discussed, which makes packaging and ground clearance much easier. I think they are around 225 lbs., but they have aluminum heads available now.
Driven5
Post by Driven5 »
Yes, the crossflow is a rather compact engine. I don't remember where I got this, but it gives a good frame of reference. Although I believe the significantly larger (and more powerful) Duratec four cylinders weigh in a similar ball park to the X-Flow.
KB58
Building: Midlana
Contact:
Post by KB58 »
horizenjob wrote:If your goal is a seven-type car, a mid engine is probably a difficult route. Maybe in a few years it won't be. Not everyone needs to be a trailblazer.
All I meant was that the weight of a car is the sum of all its components. For front-engine layouts only, for example, say you want to use the super-light Subaru to make a lightweight wonder, then throw it ahead of a heavyduty 120lb tranny and 150lb truck rear axle. It ends up being as heavy - or heavier - than using a heavier engine but lighter tranny and axle. I know it's obvious, but not so much when looking at the engines separately.
Philippe
Post by Philippe »
horizenjob wrote:It is reasonable to compare weights of the components of a drive train. Particularly if you have settled on a seven-type Locost.
This is all a good discussion and the figures and pictures provided above are tremendously useful. However, I tend to share KB58 's views that the goal (with any sports car) is a minimal weight or optimal weight to power ratio. This means that engime weight figures while usefull cannot be isolated from the other drive train components if one want to be consistent :D .
Philippe
horizenjob
Pounds are pounds, and we agree more is not better. Philippe is probably on the metric system, but we will let that slide for the purposes of this discussion. :-)
I think comparing drivetrain weights probably removes the question of which pile to weigh the clutch and flywheel in, those parts seem to regularly be left out...
But if your discussing weights for a seven type car, seems like it's possible to separate parts that are on opposite ends of the car. For instance, in the search for an appropriate axle, it does not help to only have drivetrain weights. That would be frustrating. Or having someone tell you, "just drop in a FWD transverse setup".
Sure the total weight matters, but for a person building the drivetrain, instead of using a self-contained unit, knowing the weight of the pieces would help. I do think there is not enough attention to the weight of the rear axle.
