It is currently August 9, 2020, 4:48 pm
Post new topic Reply to topic  [ 148 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
PostPosted: September 1, 2005, 8:56 pm
Ford
Duratec 2.3L
http://en.wikipedia.org/wiki/Ford_Duratec_engine#Duratec_23
(There is a HUGE range of engines currently under the Duratec name I am primarly concerned with the 2.3L, a list or models found in)
23EW = Mazda 3, Mazda 6, Ford Focus (built in Mexico)
23NS = Mazda B2300, Ford Ranger
http://www.escortfocus.com/html/2_3_duratec.html
(built in Dearborn,Mi)
The Duratec E = California P-ZEV emissions.
http://www.quad4rods.com/Duratec.htm
Zetec
http://en.wikipedia.org/wiki/Zetec
(General information and models its found in)
It is used in cars such as Ford Mondeo, 1995-2000 Ford Contour/Mercury Mystique, 1999-2002 Mercury Cougar, 2000-2003 Ford Escape/Mazda Tribute, 2000-2003 Ford Focus and 1998-2003 Ford Escort ZX2. It has been made in 1.25L, 1.4L, 1.6L, 1.7L, 1.8L, 2.0L and 2.3L capacities.
The Zetec is also the basis for the Formula Ford 2000 series from 2003 where it replaces the older Ford Pinto and Ford Kent.
Honda
S2000 and lots of cash..Input welcome.
Kia
The 2004 Kia Sorento four-door SUV is powered by a 3.5-liter V6 engine with 192 horsepower. A five-speed manual transmission is standard, a four-speed automatic transmission is optional.
Mazda
http://en.wikipedia.org/wiki/Miata
(great primer for Miata)
http://forum.miata.net/vb/
(a good forum for miatas)
Duratec 2.3 L, see ford
RX7, RX8, cosmos, RX3, also see Ford Duratec above
Mitsubishi
Ideas & Inputs...Suggestions welcome?
Oldsmobile
Quad-4_engine FWD made RWD with adapter from Mantra
http://en.wikipedia.org/wiki/GM_Quad-4_engine
http://www.quad4forums.com/
http://www.quad4rods.com/Quad4.htm
Adapters for Quad 4 for Middys or RWD
http://www.quad4rods.com/Catalougue.pdf
Susuki
Swift motor Samuri RWD trans
http://www.off-road.com/suzuki/samurai/engineswap.htm
Toyota
Ideas & Inputs...suggestions welcome
I welcome any thoughts and ideas i can add to this section. I would like to build a list similar this austrailian list with model dates and part numbers and general availablity.
Austrailian Engine Information
http://www.adelgigs.com/aussieengines.shtml
Also an interesting read is this engine swap site.
general engine swap info
http://members.tripod.com/~grannys/listbyengine.html
Dodge
The Jeep/Dodge AX15 5-speed, the Jeep NV3550 5-speed and the 87-92 Toyota Supra Turbo R154 5-speed all share the same case to bellhousing bolt pattern.
As such there are a number of possibilities that can be had when a 5-speed is desired:
94-95 Dakota 2.5L bellhousing: Connects R154 to any K car based 2.2L-2.5L L4 in a RWD application.
94-99 Dakota 3.9L V6 Bellhousing: Connects R154 to any 3.9L V6 and any 273/318/340/360 V8.
96-99 Dakota 2.5L bellhousing: Connects R154 to any Jeep 2.5L L4. Because of it's GM inherited bolt pattern, also works with any Buick FWD V6 and supercharged V6, any Chevrolet 2.8/3.1/3.4 V6, any Cadillac 4.1/4.5/4.9 V8 and with a minor modification, any Olds Aurora DOHC V8 and Cadillac DOHC Northstar V8.
88-99 Jeep 4.0L L6 bellhousing: Connects R154 to any AMC 290/304/343/360/390/401 V8 and any 72 and later 232 L6 and 258 L6.
01-03 Jeep Liberty 3.7L V6 bellhousing: Connects R154 to any 3.7L V6, 4.7L V8 and 5.7L Hemi V8.
R154 Ratio’s
1st 3.30:1
2nd 1.95:1
3rd 1.34:1
4th 1.00:1
5th 0.75:1
Rev 3.20:1
The R154 is a particularly robust transmission. It shares it's design with the AX15 but is built to a different spec. Not in the Tremec class, but better than a T5. It would work well in certain applications. The deciding factor to use something like this would probably be cost. Good used R154's can be had for about $300 and bellhousing for about $50. Converting to a hydraulic clutch would add a bit more expense but still, nowhere near the price of a Tremec. So, if you've got a 318 2 barrel in your daily driver, this might be for you. It should be pointed out that Australians LOVE these gearboxes for V8 conversions.
http://www.turbododge.com/forums/showthread.php?t=22438
Please dont flame me this is just a partial list I want to make a complete list I NEED your help!!!!
I'll keep an eye out for you!
To err is human...
I am more human than most.
PostPosted: September 1, 2005, 10:27 pm
Here's a good list of GM engines w/identification numbers which should help anybody looking at an engine which was removed from an unidentified vehicle. It lists: MAKE AND YEAR, C.I.D. LITRE BORE CYL., DESCRIPTION, BLOCK CASTING NUMBER, HEAD CASTING NUMBER, and CRANK CASTING NUMBER.
http://www.butlers-a1.com/chevym.htm
PostPosted: September 1, 2005, 10:47 pm
a s2000 engine from honda is suposed to bolt to a rsx tranny.. so any 2,0 and 2.4 engine could bolt to an s2000 tranny for rwd.. so you can have between 160 and 300 hp with this transmission, a cheap 2.0 from base rsx to 2,4 bottom ans type s head... depending on budget on canada i found s2000 tranny from 600$ cdn and 2.0 liter base rsx emgine from 800$ with all injection wiring and ecu... king of cheap...
PostPosted: September 1, 2005, 10:48 pm
i must add that i'm looking to mate them to verify the fiting, i'll come back abd post info as i will have them
 Post subject: Mitsubishi
PostPosted: September 1, 2005, 10:54 pm
The 4g63 from the Talon/Laser/Eclipse will bolt up to the tranny from a Dodge D50/Mitsu Mighty Max pickup.
--JOsh
 Post subject: Re: Mitsubishi
PostPosted: September 2, 2005, 12:29 am
--JOsh
also Hyundai Pony and Stellar (for Canada) and Plymoth Arrow.
The old 70s Dodge Colts also have the Mitsu 4G32 motor and are rwd.
PostPosted: September 4, 2005, 7:27 am
Nissan 240sx, KA24DE or KA24E heavy cast iron lump with large displacement and decent aftermarket support. Cheap as dirt to replace.
Kia Sportage (older models) have a poorly managed version of the Mazda FE3, which you could use the Mazda Miata trans for....
I'd also recommend a small list of highly viable JDM imports that will come with RWD trans.... Such as the Nissan Silvia SR20DET and the Toyota 4AG, many variants which could be used, like the 20valve for example, providing you can find or import the RWD trans. This is a very gray market thing though, due to emissions.
PostPosted: September 13, 2005, 9:40 pm
Dave wrote:
--JOsh
Also, Starion/Conquests have a RWD SOHC that eats head gaskets. Mighty Max/D50 used some other engines, including 4G64 SOHC. None of which have any potential close to even a non-turbo 4G63.
In Australia, there was also a SOHC 4G64 Starion, but good luck finding one to import ;)
PostPosted: September 16, 2005, 1:55 pm
Acording to Del Long, who runs a RSX powered 7 in Solo2 D Modified. The FWD RSX engine does NOT simply bolt up to the S2000 RWD transmission.
PostPosted: September 16, 2005, 2:22 pm
Also the S2000 rotates the "usual" way - most other Honda four cylinders rotate the other way so you'd end up with one forward gear and mulitple reverse gears. Not sure about the RSX engine though.
The Corvair is the only rwd vehicle that I can think of that rotates the same way as most Honda 4 bangers.
PostPosted: September 16, 2005, 3:59 pm
All of Honda's current engines rotate the usual direction (K series - RSX, Civic, etc., S2000 engine is just a RWD variant [F? series] of the same family). However, the widely availible and very popular old B series do rotate the wrong way.
PostPosted: September 16, 2005, 4:02 pm
GM
Global V6
These engines were designed to be as compact and as light as possible so they are a good fit for a locost. The Global V6's are used in midget race cars and marine racing, so theres plenty of support from the general to. The FWD engines have aluminum heads and the RWD have cast Iron, the FWD varients all make more power then the RWD versions. Any of the Global V6's can be mated to numerous transaxles, and can be mated to the T5, and T4 since they share the same bellhousing bolt pattern. (the T56 might also work, but no one has tried)
Theres also a DOHC version, and a VVT version. Lots of different versions of this engine to make a short list of, www.60degreev6.com has all the details for this engine as well as the others.
Pushrod
RWD- 2.8, 3.1, 3.4
FWD- 2.5 (only as a DIY) 2.8, 3.1, 3.1 Turbo, 3.4, 3.5
PostPosted: September 16, 2005, 4:43 pm
I'm new to Locost , however
All 60 deg GM V6's bolt to T5's?
According to that website this motor has been in production since 1980.
Seems like a great choice for a locost.
Am I missing something?
PostPosted: September 16, 2005, 4:58 pm
Its a little tall - need a hood scoupe. It is very light for a V6 though.
There is a zillion variations on the T5 - I'd stick to ones out of F-Bodies and S10s.
PostPosted: September 17, 2005, 8:45 am
yes all 60 deg V6's can bolt to them, provided you pick up the correct bellhousing. Pushrod's aren't that tall, a lil mini scoupe makes them fit just fine. Theres also another site i forgot to mention that sells some parts to make the FWD versions more compact to if you want to use the stock narrow frame. Killerbv6.com If you're using the +4" frame there shouldn't be any real fitment issues though. They also sell the bellhousings for the FWD cars to mate to the T5, but you can find them in junkyards out of fbodies and S10's etc.
