Short list......
Ecotec 2.2L, 2.4L, 2.0L, solstice trans, it has ben commented on that a Colorado/caynon maunual will work. (motors can be had cheap)
http://www.locostusa.com/forums/viewtopic.php?t=881
Duratec 2.4L Ford or mazda same motor
http://www.locostusa.com/forums/viewtop ... ht=duratec
Quad 4 special adapter/bellhousing needed.
Zetec
Dodge 2.4L, 2.2L, will mate up to a jeep liberty trans or dodge dakota trans...make it turbo and you beat Dodge to the razor punchline.
http://www.allpar.com/model/concepts/dodge-razor.html
V-6
Hmmmmmmmmmmmmmm
Saturn uses a honda V-6 only in auto trans
GM/GMC Camaro, S-10, G-6, GTO (had to a sneak v-8 in),
Kia Serento uses a
world motorThe 2004 Kia Sorento four-door SUV is powered by a 3.5-liter V6 engine with 192 horsepower. A five-speed manual transmission is standard, a four-speed automatic transmission is optional.
See this thread
http://www.locostusa.com/forums/viewtopic.php?t=83
Most honda motors are a wash except for the new f(?) K(?) series because of rotation direction. (unless you use it as a middy) V-6's should be ok but dont know of any trans that fits.
Do a search for the motor you want to use....chances are it has been discussed.
