Rare 1980 Blakely Bearcat "S"
Ford 2.3L Xflow 4 cylinder OHV engine wtih a stock 4bl carb,and 4 spd manual transmission. with only 6,550 miles. Has new brakes, side load exhaust, Hurst T shifter, top and side windows but I have never used them.
Gelcoat is showing some black splocthes is a few areas, may be bleed through from the mold process, don't know why. Has full top, 15 x 6 inch alloy wheels. Custom front suspension. Custom 3 link rear Ford differential, rack and pinion steering with front disc brakes, rear drum, Special upgraded seats ordered from the factory, can use a little work, AM/FM with 6 CD player mounted between the seats, detachable rear speakes, Two speed wipers (3 blades Motor not installed) - Halogen headlights, Leather wrapped steering wheel. push button start
Clear title in hand.$7000
George 954-575-2111
