This Lotus 7 frame is all round tube, and welded by the welding instructor ar WyoTech. Not quite finished welding, there is a loose tube and some spots are not welded all the way around. Also it is a bit wider at the front than the stock Series 2 nose. $1,500 for frame and nose
The project also acquired a Buick 215 block from 1963, and a 1995 Rover 215 engine with carb manifold. And an Escort motor with a Weber carb. $750 for both block and engine, when sold with tube frame.
Have drawings of round tube mounts, just a bit more fabrication than square.
Returning to mid engine build, seeking Europa body panels, especially seeking a molds to make duplicate body panels.
Mark. 415.625.3644. San Francisco. Can deliver.
