I hate to be the guy that starts projects and never finishes them but life always seems to get in the way for me. Basically I have almost everything you need to put a duratec into whatever project you have. I was going to put one in an Mgb, but this stuff would easily work as well in a seven. I have 2 engines, one 2.0 and one 2.5. The 2.5 needs the front cover changed, I have everything needed to do that. For fuel I have a kit from danst engineering from England. 40mm bike Carbs sonically cleaned, manifold, pipercross filter, and throttle cable kit. If you want to go fuel injected I have a set of gsxr750 carbs that fits the same manifold. I was going to use megajolt for ignition so I had bought a Ford edis with plug wires. You can use this stuff if you use megasquirt also. I have an nc miata alternator, and also a small Suzuki alternator with a lightweight pully if you want to use a 3 wire system. Just need to make a mount for it. Transmission is a 2009 nc miata 5 speed. Mates right up to either engine. If the engine is upright the transmission will tilt 10 degrees to the driver. This can be delt with with a bent shifter or just left alone. 10 degrees isn't a big deal. Look at the list for everything else I have. Ask any questions you may have. I would like to sell this in the biggest chunks I can, if someone wanted it all I would def discount. Basically to have a Complete drivetrain the only other things you need is an nc miata flywheel and clutch. If I don't have price listed on item make an offer. Let me know if the pic link doesn't work, I haven't done this in a while
-Ford edis and plug wires SOLD
-Crane cams titanium springs 260
-Arp pressure plate bolts
-Massive balance shaft delete SOLD
-Massive timing tools SOLD
-Arp crank pully bolt SOLD
-Injector plugs
-nc Miata oil pickup tube
-Top gasket kit SOLD
-Crank pully diamond washers SOLD
-Crankshaft front seal SOLD
-Engine mounting kit for RWD Motorsport 100 SOLD
-Nc miata oil pan 100
-Focus oil pan
-Ranger oil pan SOLD
-2.5 front cover SOLD
-Nc miata 5 speed 400
-Fusion 2.5 engine 500 SOLD
-Focus 2.0 engine 300
-Lightweight Alternator pully with 3 wire Suzuki alternator 90 SOLD
-Motorcycle carb kit from DanST engineering 600 SPLIT UP
-S2000 headers with flange cut off 75
-Gsxr 750 throttle bodies 100 SOLD
-Steel exhaust flange and gasket 100 SOLD
-Injector rail bar stock SOLD
-Vacuum manifold
https://imgur.com/a/Xhqvg
