It is currently April 17, 2024, 9:42 pm
PostPosted: November 18, 2020, 1:37 am
*UPDATED*
Selling a complete set of 4 Strange Engineering double adjustable coil overs, model S5004. Brand new, only mounted for a test fit. Hyperco springs are 2x 250 lbs/in and 2x 600 lbs/in. These were bought for a custom race chassis but can be used for many different applications with different springs. $950 OBO.
https://www.strangeengineering.net/prod ... ring.html/
Application
Drag Race Vehicles
Short Stroke
2.62″ thru 3.86″ – A-Arm Systems
3.86″ – Some Dragster 4-Link Systems
Long Stroke
4.64″ thru 8.15″ – 4-Link & Ladder Bar Systems
Description
Double Adjustable Coil-Over Shock
Sold as each
Dimension A
Stroke 3.86″ / Extended 13.84″ / Compressed 10.00″
With .563″ Bump Rubber Installed
Stroke 3.297″ / Compressed 10.563″
Recommended Ride Height
11.75″ – 12.125″
Accepts 10″ x 2.5″ ID spring – Sold separately
Features
• Lightweight aluminum body
• 10 extension & compression settings
• Provides a wide range of control
• Easily accessible independent external adjustment knobs
• Allows quick adjustments for varying conditions
• Coil-over design simplifies changes to ride height
• 1.00″ wide high misalignment spherical rod ends
• Ability to be rebuilt or revalved
Options
– .500″ or 1.500″ wide spherical bearings
– Polyurethane bushings with steel sleeves *
– Upper stud mount with rubber cushions *
– Custom valving *
