It is currently Tue May 21, 2013 10:10 am
Post new topic Reply to topic  [ 371 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 25  Next
 Post subject: Re: What's on Ebay/Craigslist/etc.?????
PostPosted: Wed Nov 17, 2010 11:08 pm
$1000 miata WITH hardtop
http://www.mnautox.com/forums/showthrea ... E-Race-Car
PostPosted: Sun Nov 21, 2010 9:06 am
Holy race tires, Batman!!!!
http://cincinnati.craigslist.org/pts/2032230951.html
PostPosted: Sun Nov 21, 2010 9:21 am
and the perfect donor...
but not running...
http://cincinnati.craigslist.org/cto/2010523948.html
 Post subject: carb approved fageol supercharger for gm 2.8
PostPosted: Thu Nov 25, 2010 6:03 pm
http://sfbay.craigslist.org/eby/pts/2071736930.html
asking price is $275. .. tempting even though i don't have anything to put it on at the moment.
Used on a V-6 Chevy Camaro -- for 1000 miles.
I've had it in dry storage for about 8 years.
K.F. Industries in SoCal marketed a kit for this engine and obtained a C.A.R.B. number of EO #D-150, as pictured.
Claimed increase from 250 HP (stock internals, Headers fitted)-- to 373 HP at 5 lbs. of boost.
Call Mike at 925-286-6185
PostPosted: Wed Dec 01, 2010 1:08 am
and another great donor, if you're alfa-minded... Says hopped up cams and Dellortos... money in resale even...
http://cincinnati.craigslist.org/cto/2045648570.html
PostPosted: Fri Dec 03, 2010 1:29 pm
E-bay listing
Some one might be abe to use these coil over shocks, just $89 /pr. Item number: 250736842748
Dave W
PostPosted: Mon Dec 06, 2010 9:56 am
located in noVAto. .. not too far away from me for a look-see
http://sfbay.craigslist.org/nby/pts/2085840793.html
1970 MGB Parts car. It's been sitting for a long time. Rusty floors, needs interior. No paperwork. Can deliver. Lots of extra parts, including but not limited to: Complete front suspension assembly, chrome bumpers, radiator, Weber carbs, S. U. carbs, drive shaft, steering rack, new air filter elements, set of gauges, pedal assembly, heater core, seat belts, door glass and mechanisms.
PostPosted: Wed Dec 08, 2010 4:00 am
http://dayton.craigslist.org/cto/2090213586.html
1979 RX7 for donor bits... well worth an offer... or a "bang bang"... :cheers:
PostPosted: Thu Dec 09, 2010 6:00 pm
http://sfbay.craigslist.org/sby/pts/2099256950.html
I am not a business, just a retired hobbyist cleaning up
If interested send me a note and I will send picture of the item/s
Datsun 240Z 1972 model, outstanding condition $14,999
Original yellow paint and black interior
280Z engine, 5 speed trans, 3.70 differential
280Z wheels with new wide radial tires, Koni shocks
restored in 2008 with complete engine rebuild
upgraded headlight wiring, new AM/FM/CD radio
performance bushing in suspension
Large flat trailer, built for RotorWay helicopter $899
would be ideal for a small race car
Bed is 12'4 x 6'6 and has 14'6 x 1 storage underneath
1 in square tube tie down all along both sides make tie down
very easy, has storage under bed for blades and tools
would make a great trailer for any purpose, very large bed
Ford T5 Tremec World Class 5 speed transmission 10 spline $495
1st 3.79, 2nd 2.34, 3rd 1.46, 4th 1.0, 5th .79, rev 3.70
I think it is for a 87-88 Mustang, no tag.
I ran it for a year and it worked fine, upgraded to a T5Z.
Trailer frame with R205-75R15 steel belted radial tires $189
Dewalt saw came off it, it is 52" x 52" usable
very heavy duty trailer, looks nice also
Would be a great motorcycle trailer 2" ball
Gasoline pump 12vdc with flow meter, 15 gal Stainless tank $239
trigger nozzle, roll around base, makes movement easy
Lexus IS300 rear end assembly with brakes, diff, suspension $499
complete sub frame assembly, ready to bolt right in
RotorWay 162F Helicopter aluminum radiator $350
It was repaired, and worked fine for a year.
Mazda RX7 85 GSL SE rear disk brake axles ea $ 69
Mazda RX7 GSLSE rear wheel bearings and seals pair $ 40
Koyo 052 3608 and B/A 052-2540 2 each avail
Datsun 280ZX fuel injection head w injection $149
Datsun 240Z 1972 transmission 4 speed, good condition $199
Datsun 240Z 1972 rear end assembly good condition $199
Datsun 240Z short block, needs rebuild, but good core $199
MG Midget transmission 4 speed 1976 excellent condition $175
MG Midget rear end differential, pumpkin, 3:90 $149
MG Midget rear end assembly with diff and brakes $299
MG Midget rear axle for disk wheels $ 59
MG Midget 74-80 front rubber bumper, good shape $ 49
MGB 74-80 rear rubber bumper, good shape $ 49
Large box of small motor parts, approx 150 items $ 89
Tecumseh, Honda, McCullogh, Briggs & Stratton, Kohler
filters, gaskets, pistons, rings, covers, ign parts
air filters, carb parts, string cords, misc parts
Wilwood 260-3378 1" master cylinder brake or clutch $ 69
PowerAdder chrome air filter 3" with MAF and 3-2.5 adapter $ 49
VDO fuel level gauge and sender for VW and others $ 49
VDO speedomotor hall effect sender FORD 340013 $ 49
Ford Mustang, Merkur XR4ti bellhousings (4) ea $ 49
D12A 6394 AD, E6ZR 6394 AA, E5RD 6392 AD, D52A 6394 AA
Ford Explorer 2001 aluminum rear drive shaft with $ 49
1330 universals, 59.5" OAL, 52.75 end to end on universals
Hirschman universal power radio antenna, new in box $ 49
Ford Drive shaft, C3AA J25, 1330 type universal $ 40
41" ctr to ctr on universals, no ends, just tube
Nissan 2004 Frontier red front left fender, small dent $ 40
could be taken out easily now fender is off
Harley Davidson V-Twin ECU ECM computer HD 26242P 12v $ 40
Looks nice, no marks on case from mounting, might be new
leaf spring shock bracket and u bolts, both sides 3 1/8" $ 40
aftermarket set, will fit any car using 3 1/8 springs
Motorguard sub-micronic filter M-723 pack of 4 $ 25
ECM, ECU, car computer 2S4A 2002 Ford Escort ECU $ 25
ECM, 1227747 89-92 Chevy GMC truck, van 350 5.7 liter $ 25
ECM, 1227148 86-89 Buick Oldsmobile 3.8l $ 25
Ford Mustang, Mercury, Xr4ti cluch arm (2) ea $ 20
D52A 7515 AC, D8BC 7515 AC, D9ZC 7515 BA
also have throwout bearings
Ford Mustang speedometer cable87-93 with electronic pickup $ 20
has black speedometer gear
MotorMite 14806 clutch cable for 81/3 Ford FAIRMONT $ 20
MUSTANG 198/2, GRANADA 81/86, CAPRI 83, MARQUIS 81/3
COUGAR 198-3, ZEPHYR see motormite.com for specs
MotorMite 14825 clutch cable $ 20
FORD 1979 FAIRMONT/MUSTANG MERCURY 1979 CAPRI/ZEPHYR
see motormite.com for specific applications
clutch arm (3)for Ford Mustang, Merkur Xr4ti each $ 20
Mustang clutch cable, ask for picture $ 20
JDJ
•it's NOT ok to contact this poster with services or other commercial interests
PostingID: 2099256950
PostPosted: Thu Dec 09, 2010 7:09 pm
No affiliation.
http://phoenix.craigslist.org/nph/bar/2097571167.html
or
http://phoenix.craigslist.org/nph/fuo/2044911284.html
or
http://phoenix.craigslist.org/evl/cto/2079503995.html
or
http://phoenix.craigslist.org/evl/cto/2101181325.html
or
http://phoenix.craigslist.org/cph/cto/2037011240.html
Lots of cheap RX-7's if that's your interest.
Tom
All your polished parts are belong to me!
PostPosted: Tue Dec 14, 2010 7:17 pm
http://toronto.kijiji.ca/c-cars-vehicles-cars-trucks-Lotus-7-W0QQAdIdZ242555506
Anyone have experience with one of these RM Cars?
Just looking for some opinions on the value?
Would you buy at this price?
Not my car, but looks interesting 2 me.
Thanks ahead of time.
Marc B
PLEASE VISIT
GTOWN.CA
PostPosted: Thu Dec 16, 2010 7:32 pm
Anyone interested in a used Caterham? Located in the San Francisco bay area. I have no personal interest but here it is.
http://sfbay.craigslist.org/nby/cto/2106885044.html
PostPosted: Thu Dec 16, 2010 10:27 pm
I just put a 98 V6 Mustang 5speed in SoCal in the FS section
PostPosted: Tue Dec 21, 2010 10:47 pm
locost on ebay
http://cgi.ebay.com/ebaymotors/Lotus-Lo ... sQ5fTrucks
"Make it a GREAT day"
Tony Chiles
PostPosted: Wed Dec 22, 2010 5:31 pm
http://phoenix.craigslist.org/evl/cto/2119409932.html
My CMC Miata/RX-7 kit. I'm in Mesa, AZ. Let me know if you're interested.
FYI, I have all the original documents, including statement of origin and paper trail of bills of sale.
