turbo_bird wrote:
Briggs wrote:
Have any of you guys used this type of axle on a trailer? They offer a 4" drop kit. Pretty pricy at a bit over $600. They also offer electric brakes as well.
http://www.etrailer.com/Trailer-Suspens ... RD545.htmlI've never seen an axle like that before. It doesn't really look like it has much of an advantage over a regular torsion flex axle to me. It might use a 4" drop axle, but the pictures look like the axle centerline still ends up pretty much right at your deck height, which is where mine ended up with my straight torsion axles. The only advantage I can see is that you would be able to run smaller wheels without running into clearance issues while keeping your trailer's track width to a minimum. When I built my trailer, I ended up using 16" wheels for a front wheel drive car to get clearance around the torsion arm and get the tires in close to the deck. If I go down to 15" or 14" I will have to push my fenders.out to cover them.
I need to search more for your axle. I only found ones that ran the full width of the trailer. I couldn't find any like the one in the pic you posted.
Do you have a link to the site you bought yours from? The ones I found were around $450 including the hubs and electric brakes.
With those, using the same wheels I have now on my trailer (14"). I had 8" of clearance from the bottom of frame to the ground. I've widen the trailer to 78"/6.'6". I'm trying to decide if I want to mount the wheels inboard or outboard.
I should prob post up my latest design I did. I figured since I plan on building a Locost might as well make it long enough to haul it as well. By the time the Locost is done I plan on having an older truck used for towing things. An older Chevy pickup with a 5.3 vortex would be nice.
