It is currently February 22, 2020, 9:40 am
PostPosted: August 6, 2008, 4:38 pm
How much tubing?
Here is the cut list for the book chassis.
http://www.mcsorley.net/locost/drawings/BookChassis.xls
1/8" PLATE
32 sq. in.
1" SQ. 16ga
1210.00 in.
3/4" SQ. 16ga
294.20 in.
3/4" OD 16ga
290.75 in.
110-ish feet of 1"x 1" 16ga tubing if you don't plan on making mistakes, more if you do.
You will need 25 ish ft feet of 3/4"X 3/4" of 16 ga RHS and 25 ish ft feet of 1" 16ga Round tube.
The book suggests 16ga which is .065 thick and comes in at .649 lbs/ft.
Multiply these numbers by 110 to get a chassis worth of tubing and you get:
16ga chassis:71.39lbs
Note this number is only for 110' of 1"x1" tubing ... not welded, no 3/4" tubing, no 1" round tubing, no floor, no roll bars, no brackets, or suspension pickup points!
Further reading: http://www.locostusa.com/forums/viewtopic.php?t=68
How much Does your frame weight?
viewtopic.php?t=3941
I'll keep an eye out for you!
To err is human...
I am more human than most.
PostPosted: April 21, 2011, 2:44 pm
FYI: the cut list moved, and is now at:
http://www.sevenesque.com/files/bookChassis.xls
PostPosted: November 14, 2011, 1:33 am
the above link didn't work.
PostPosted: November 14, 2011, 10:58 pm
I just tried it and it did work for me. If it stumbles again, click on "plans on the left side of the page and find the "cut list" in the second paragraph.
walt :D
