We use the heat shrink sleeves and handheld printer for wire labels at work. They would probably hold up OK in a car, as long as they're out of the sun. They do get dirty easy though, so make sure your hands are clean when putting them on. These are the brand we use, but I'm not sure which exact style they are. If you don't want to buy a printer, you can write on them with an acid pen and it will be just as durable, just not as neat.
http://www.bradycanada.ca/en-ca/product ... e-sleeves#They also have some good info about labels on the website.
http://www.bradycanada.ca/en-ca/feature ... ire-markerFor my car I bought a Painless Performance universal wiring harness. It had the fuse panel already terminated and all the wires were marked with a circuit number and description every foot or two, as well as being color coded. And the booklet has a list in the back of where each wire should go. I looked at buying wire and doing my own harness, but decided against it when I found out how much good quality wire costs in small quantities and enough different colors to be able to trace it all out later.
viewtopic.php?f=35&t=7587viewtopic.php?f=33&t=18172
