It is currently April 21, 2019, 4:13 pm
PostPosted: November 27, 2016, 10:32 pm
Thinking about headlamps for my rear-engine Crusader project.
The original design was never truly street legal.
Thinking of adding modern lights at the top of the fenders to get them high and wide enough.
Want them as small as possible.
PostPosted: November 27, 2016, 10:58 pm
There are some projector units made for motorcycles that are very small.
PostPosted: November 28, 2016, 1:08 am
Man of Constant Hazard
That is going to vary state-to-state. Do you have the regulations for Nevada? (I assume you're talking about Nevada.
From memory, Kentucky didn't spec a size. Only a height and throw angles. (Not that they measured the throw angles during the inspection.)
Visit my [Locost 7 build log]
PostPosted: November 28, 2016, 3:56 am
Nevada tends to mirror the Fed. standards for most vehicle specifications.
Although they did once tell me that I could not register a motorcycle powered car here.
I think I know a couple of ways to get around that particular stupidity. :wink:
Fed's have a spec range for height and width, I'm sure the lamps have to be DOT approved as well.
I've never heard anything saying MC lamps cannot be used on a car.
So where would I source these lamps?
PostPosted: November 28, 2016, 9:17 am
Ben_Modified over on Grassroots forum had a set in hand, I have a query in to him for the source.
Meanwhile look on Ebay for ideas - motorcycle headlight universal projector
PostPosted: November 28, 2016, 10:16 am
Just a comment. DOT "approved" lighting is a misnomer. DOT sets the standards. They do not approve anything. If you are a sucker for punishment, you cam read the requirements here: https://www.gpo.gov/fdsys/pkg/CFR-2008-title49-vol6/pdf/CFR-2008-title49-vol6-sec571-108.pdf There are >999 places where the word "headlamp" is used. Have fun.
And if you happen to find a particular light that claims it is DOT approved, or has the word DOT on it somewhere, T Be aware that here are technically different photometric requirements for motorcycles. Conceivably, marked DOT headlights may be for Motorcycles and not be suitable for Passenger Vehicles.
All that technical BS being said, what you will be inspected to will likely vary from what you are required to meet , based on the particular state and individual inspector you get
BTW some of us use the electrical box intended for motorcycles to cancel the turn signals. I just saw that these are not compliant with requirements for cars or trucks.
S5.1.1.5 The turn signal operating unit on each passenger car, and multipurpose passenger vehicle, truck, and bus less than 80 inches in overall width shall be self-canceling by steering wheel rotation and capable of cancellation by a manually operated control.
I guess my 1956 MG wouldn't meet that requirement, as it had a funky pneumatic timer. Fortunately, DOT requirements are not retroactive. Most of us who use the SEMA sponsored "Custom Vehicle" route to register our cars get to declare what year goes on the title. So we only HAVE to meet safety (lighting) requirements in effect in that year, like 1960 in my case.
PostPosted: November 28, 2016, 11:19 am
Yes many times motorcycle headlights will blind oncoming cars. Cars have a left and right light and they have different light patterns.
If you have Xenon headlights it's easy to see as the cut off point will be lower on the left beam than the right.
PostPosted: November 28, 2016, 11:06 pm
http://www.ebay.com/itm/BikeMaster-Piercing-Beam-Headlights-High-Low-Beams-FB3-9-BLK/231698728137
PostPosted: November 29, 2016, 1:19 am
As low as these would be mounted blinding oncoming traffic should never be an issue so long as they are not aimed UP.
Went to the link, looks like I would need to make a housing for them as the pods are ugly.
Or at least make them quick-detach and remove them during the day.
