trackfodder wrote:
SkinnyG wrote:
Well, I picked up a Miata battery for less than twice the price of another garden tractor battery. It has a two year replacement warranty, and 72-month pro-rated. Should do ok.
I read something interesting online. If a battery dies totally, sometimes the charger won't try if there is no flow. The suggestion is hook a booster battery to it to give it something to respond to the charger circuit with and it will charge. If there is a need, I can dig it out of favorites and post here.
I can add some anecdotal evidence here. In December, the battery in the Slotus went dead, totally. Wouldn't even light up the indicator bulbs on the switch panel. I hooked it to my charger, which went to full on charge, then shut off. A second or two later, it went back to full on and shut off. It cycled like that for about five minutes until I unplugged it.
I hooked up jumper cables to a (running) truck battery, charged the one in the Slotus and ran all day with it. When I got home, I tried hooking up the charger again and it worked just fine. Tried it on two or three other batteries, worked fine. Still using the same charger to this day. (And the same battery, an Optima dry cell!)
I think the battery was too dead to take a charge from the plug-in charger, but it seemed to charge up just fine with jumpers!
Curiouser and Curiouser, said Alice...
JD, father of
Quinn, Son of a...
Build LogQuinn the Slotus:Ford 302 Powered, Mallock-Inspired, Tube Frame, Hillclimb Special "Gonzo and friends: Last night must have been quite a night. Camelot moments, mechanical marvels, Rustoleum launches, flying squirrels, fru-fru tea cuppers, V8 envy, Ensure catch cans -- and it wasn't even a full moon." -- SeattleTom
