Locost_Johnh wrote:
As far as I can tell, all lawnmower (and motorcycle batteries most likely) are crap. I finally got tired of my lawnmower battery crapping out after a year and shoe horned in a small car battery. That was maybe three years ago and still working. If you race, the weight is certainly a factor, but the convenience is great
John
Um, no. I've owned and ridden motorcycles for 38 years, and if you treat their batteries well, they'll last as long as any car battery. you can't charge them at an amperage rate beyond their capacity to receive, or their life will diminish precipitously.
If I'm not mistaken, batteries should be charged at a rate one-tenth of their rated amp-hour capacity, so, my 14 amp-hour Yuasa in the B-3 (which is operating on the same motorcycle electrical system as it was. gets charged at 1.4 amps (my plug-in charger has a 2 amp setting. and that's the most the bike battery gets when I'm maintaining it during the winter), whereas the 60 A/H battery in my car can take the 6 Amp setting on the charger.
if you are using a motorcycle battery in an automotive electrical system, and the car alternator is putting more amperage into the battery than the battery has capacity for, you'll definitely shorten the life of the battery.
Currently the 14 A/H motorbike Yuasa in the B-3 has been in use since the spring of 2010 and shows no signs of quitting.
The B-3 build log:
http://www.locostusa.com/forums/viewtopic.php?f=36&t=13941 unfortunately, all the pictures were lost in the massive server crash
https://www.locostusa.com/forums/viewtopic.php?f=36&t=19012Again, all pictures were lost.
