After a bit of thought, decided to move my steering wheel a bit. Always seemed too low and a bit too far away. Decided this when the crappy (new) u-joint has a little play. Replacing that and decided to lengthen the shaft going down to the rack since it is little short. Wanted a bit more in the splined section. If I'm going to do that, just move the whole column closer by an inch. Pretty sure there is about 6" of shaft in the steering tube. I should be able to cut the weld, slide the shaft out and reweld. That gets the wheel an inch closer after I move the the column. To do that, I need to make some new brackets. Need to make some special spacers or do some welding. Making a new bracket and bushing for the front attachment and haven't decided for the rear mounting point. I like the idea of welding a new plate on there but it seems like a spacer made out of 3/8 aluminum would be fine.
After doing a couple of calculations, lowering the front mounting point about 1/4" and raising the rear mounting point 3/8" will get the wheel sitting about 3/4" higher. That should be much better.
_________________ Volvo 240/P1800 Based Locost 2004 Aprilia Mille Factory Kawasaki ZRX1200 2002 Toyota Tacoma 1999 BMW M3
