Hello,
I am new to this forum and i was needing some help with some of the suspension designs. I will be using the wilwood Mustang II drop spindles and I have deigned them in cad and imputed the correct dimensions into vsusp. here is the link with the suspension design.
http://tinyurl.com/zxhmpebIn the front i am planning on running 275/40/17 with a 0.24 inch offset rim with a 1.5 inch wheel spacer and in the back i will be running 315/35/17 with a 1.1 inch offset on the rim and will have a 1 inch wheel spacer.
Could some of you guys run through my measurements and recommend any changes? Also i almost forgot to mention, that the frame in the rear is 46 inches wide, this is why i was thinking of adding in the wheel spacers.
I will be using a wilwood brake kit 140-12275-D for the front which will offset the hub by +.55. I have not incorporated that into the program yet so a bit of help regarding that too would be nice.
Your help will me much appreciated, and thank you in advance!
