Omaha Vette Graveyard wrote:
mjalay,
Please don't confuse me with Sam_68, I never criticized your setup.
The vsusp examples I linked were intended just as I stated, to give examples of what lots of folks consider would good roll center fixity. I just moved things around from your vsusp examples to get that, neither was intended as an actual car's suspension design.
If you'd like to see that kind of roll center fixity (using the same principles) in an integrated suspension geometry check out the C5 Corvette. The camber gain, KPI, scrub, track, anti squat/dive and such are excellent, and the geometric roll center is almost perfectly fixed. I have driven that car, and it works very well.
My guess is that your car is light, doesn't roll all that much, and doesn't use all that much suspension travel, which makes it not very sensitive to a migrating roll center. You can therefore prioritize other things with little or nothing lost. You'd never really know that for certain, however, unless you tested it on the track to see which is actually faster, easier to control at the limit, and/or less taxing.
The geometric location of the roll center does mean something, and it does effect the way the car drives. Right? If this is actually the case, a car with a roll center that moves laterally in roll will drive differently with the car at 1 degree of roll angle than it does at 0 of roll. Is that change a favorable one?
-Graveyard
oh no and that's way I said i understand the point you were trying to make. Yes, from what understand our cars are so light and generally have such a lower center of gravity that you can ignore it or put it at the bottom of the list along with roll bars.
Have a link for that C5 stuff?
