Ordering new custom shocks http://locostusa.com/forums/viewtopic.php?f=5&t=19029 |
Page 1 of 1 |
Author: | mjalaly [ September 1, 2017, 3:47 pm ] |
Post subject: | Ordering new custom shocks |
So I am in the process of ordering new custom adjustable bilsteins (my car seems to be too light in the front to buy anything off the shelf). What i am having issue with is making a graph of what I want Bilstein to make. Using this cacualtor http://farnorthracing.com/autocross_secrets16.html This is what I have but what values do you guys think would be fitting for Tire spring (its hard to measure), design Dampening ratio and digressive knee? Attachment: Capture.JPG My front spring rate is off since my front shocks are really over damped and I would think it should be closer to 125lbs. The rears are not too bad. * Most spring calculators assume you don't have push rod supension. http://www.ridetech.com/info/wp-content ... ulator.xls I actually did this for the other car I was working and the driver ended up using a very slow rebound (2 click out of 10) because he thought it was too harsh. I think it is great. Here is what i get if I use the built in Tire spring rate, design Dampening ratio and digressive knee Attachment: data 1.JPG Attachment: data2.JPG
