It is currently January 17, 2019, 12:51 am
PostPosted: February 26, 2018, 6:58 pm
So, I'm sitting here with a good old Moog ES2074R, otherwise known as a Ford Courier tierod end. That's the one Kinetic recommends as an upper ball joint.
It *looks* like the centerline of the ball pivots on the centerline of the threaded shank - the shank and ball housing are offset - but I remember a flap among the stock car guys a couple-three decades ago when they found out the pivot points of several commonly-used ball joints weren't where they thought they were.
Is there a good non-destructive way to determine the pivot point? If I have to fire up Mr. Angle Grinder I'll do so, but I have the same problem with the lower ball joints and the tierod ends, so that would be at least three joints I'd have to sacrifice.
PostPosted: February 26, 2018, 7:26 pm
Take pictures with the ball at the extremes, then extend lines on the pics down the center of the shaft. Where they cross, presto.
PostPosted: February 27, 2018, 8:43 pm
That's starting to look like the best way.
