It is currently April 17, 2024, 10:09 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
PostPosted: April 16, 2018, 6:07 am
Hi Guys
With thanks for the help I've had here, and on other pages, I would like to seek further advice.
I am currently living in Thailand and trying to tackle a project of this nature seems not too easy, with little local support for, or understanding of, such weird activity...
My biggest problem to date is sourcing uprights/knuckles/kingpins - none of the knuckles commonly used in the West are available here, and I don’t feel too confident about fabricating my own... e.g. where to actually start on the design...?
However I have come across a number of modern knuckles which all utilise the MacPherson strut principle so my idea is this: remove the strut, and perhaps the upper inch or so of the knuckle, and drill the casting to take a normal ball-joint. As all these cars utilise FWD I will also have to find a way to seal the rear side of the knuckle.
This might not be too practical but let me ask two questions:
1. Is this idea too stupid to be believed...?
2. Has anybody else tried anything of this nature...?
Many thanks, Mangpong.
______________
PostPosted: April 16, 2018, 7:06 am
[quote="MangPong"]Hi Guys
I don't think that anything we do to build these cars at home can be called «stupid». Rather I would use: unpractical or too expensive as qualifiers. Here again I can only tell you what I have done with my two builds, which is not necessarily the best course..
In both cases I have worked from a «donor» vehicle; i.e I bought these cars for «parts». The first one was a Ford Aerostar van from a neighbour. It was not the best choice but it was there and cheap. With my neighbour's help I torn down the mechanical components of the vehicle, including all suspension, steering and brake systems. For the second build I went the same way (a 1965 GM Corvair). Some of the donor components needed to be fixed or remanufactured however, and there I found that the core parts were often needed to get new ones. The advantage of using parts from a donor vehicle is that they are designed to fit together . This leaves you with a simpler job to build a chassis that will receive these parts. Your best course of action would be to buy a small rear wheel drive car from a scrap yard or a neighbour, tear it down to get what you need . (alternatively ask the scrap yard to tear a car down for you). For new components, in North America we would also rely on after market part retailers or ebay. I hope this helps. :)
PostPosted: April 16, 2018, 7:52 am
MangPong
There are several builders here who have modified strut type knuckles, with good results. Typically the upper section is modified like your photo if using rod ends or they add an extension that allows a ball joint to be used. Once you have determined the basics of your front suspension, caster, camber, KPI, and scrub radius, that you want, you start looking for the knuckle, or if you already have a knuckle, then work backwards to see what parameters you can best incorporate into the up-right.
Just like everything here, be ready to make a few compromises. Most of the knuckles will for a FWD system and designed to reduce torque steer. To get a good scrub radius will require an inboard upper B/J extension or off set wheels. DaveW
PostPosted: April 16, 2018, 10:25 am
There are several ways to adapt a McPherson strut knuckle to upper/lower control arms. Since the upper joint "generally" sees less force, the use of an appropriately sized rod end joint might be applicable. I did this on the front end of my build by building an adapter which bolted into the holes previously used for attaching the McPherson strut. See my photo below. It's not very pretty. But it is functional.
I eyeballed the upper mount of the McPherson and put the rod end along that line, keeping the scrub radius that Davew mentioned under control. Of course, that only works if you use the original wheel offset.
We are a bunch of inventors here. There is no one solution.
PostPosted: April 16, 2018, 1:23 pm
My gosh, you guys (collectively and individually) are magic - good ideas and rapid responses...
First, I am pleased that my (possibly silly) idea hasn’t phased you - I post them here because I'd rather be shot down in flames here than end up in a ditch beside the road...
Secondly, it’s just nice to be able to discuss... to just throw out ideas... None of my friends, family, neighbours has any understanding of what I'm trying to do... and usually ask (if they ask anything), ‘Why’’’?’ Do we all have this problem...? lol.
phil
I'm sure the ‘donor’ idea is good - however, in this socio/economic culture there is no rubbish. Old cars run, usually with poor maintenance, until they just stop... and even then, if you offer to take the wreck away for them, they will expect payment - perhaps 10x what it might make in the West. Well over $2,000,,,!
Secondly, I am aiming for a rear-mounted motorcycle engine/transmission unit, which hopefully will be the ‘donor’, but it won’t help the front end. All I would probably take from a donor car would be uprights, brakes, and steering.
I've spent the past few weeks touring the area for scrapyards, such as they are... and they are rather different to ‘back home’ when you trawl around various models of cars to see what’s been left. Here we have breaker’s yards, where they break out everything they think has value and they hang the bits for you to see... And they specialise: one place will have engines/gearboxes; another rear axles; another suspensions, and racks... indeed there are racks and racks of racks... It was amusingly eyeopening.
daveW
Thanks for the confirmation of what others have done with MacPherson struts - very gratifying to know others have already tried it, and not ditched the idea. Until now I've been working on the suspension design, around compromise dimensions I've found online or have guessed at, and have now had a bit of a shock that the uprights that many of you guys have been using are now in very short supply. The only offer I've had hear for anything resembling what we all like is from Isuzu, and is very big and heavy... more than the Miata... and the Miata is only available here as a special import order - there aren’t going to be many waiting to be scrapped... lol.
I feel like I'm becoming an expert at The Art of the Immaculate Compromise...
rx7locost
This is just brilliant - always love a photo or a diagram. What you have done here is almost exactly what I was imagining... except... where I was thinking of removing all trace of the strut, and then trying to mount a ball-joint directly to the upright... your method of using the MacP bracket is so much better... and a wizard wheeze... And, if you fit the bolt inside the adapter-bracket it will be pretty(er) as well - although it’s amazing what a dab of paint, and big fenders will do... lol.
Having spent two days online looking for ‘solutions’ I've now spent an hour staring at the sheer simplicity of your solution. I feel so relieved this night... Thank you.
For All...
One thing I'm thinking... what to do about the loss of the driveshaft - I'm assuming the rear face of the upright needs to be covered, to protect the hub/bearing. Do I just screw or weld a steel plate over the hole...
Many thanks all, Mangpong.
______________
PostPosted: April 16, 2018, 3:06 pm
Rather than cutting and drilling on the stock spindle, I prefer bolt-on adapters that have no chance of compromising the integrity of the factory parts...More like these.
...Or these.
...Or these
PostPosted: April 16, 2018, 7:34 pm
Or, look for the knuckles off the front of a 2-wheel drive (rear wheel drive) pickup truck. My suspension donor is a 1989 Isuzu Pickup. A Toyota may be more common for you. Toyota 2 wheel drive vans used to be popular too.
Warren
PostPosted: April 16, 2018, 9:00 pm
Toyota Previa comes to mind!
PostPosted: April 23, 2018, 12:12 am
Sorry for the slow response, guys... I've had a few intensive days travelling around looking for a donor - and for rose-joints - after asking at over a dozen potential stores only one guy reticently claimed to know what they are, but didn’t have a clue where to buy them...
Driven5
Many thanks - brilliant suggestion - don’t know why I didn’t think of it. Totally agree about “no chance of compromising the integrity of the factory parts”...
rx7locost’ gave a similar reply, which makes me feel pretty inept, mentally... lol.
Warren Nethercote
I was offered an Isuzu upright, that was designed to take ball-joints top & bottom, but it seemed rather large, and very heavy - over 5kg. bare upright. I didn’t get a size but can you give a height measurement of yours - just the upright without balls... please?
ngp-mike
I haven’t seen any secondhand Previas, but they strike me as large as well. I have been looking at the baby Honda and Mitsubishi (Brio/Jazz & Mirage) but they’re not old enough yet to be cheap donors. My best bet seems to be an accident write-off, but most accidents here are head-on collisions... and the engines often end up in the driver’s seat... Hmm...
Nobody said it would be easy... but I've not stopped looking.
Thanks for all your suggestions - don’t be afraid to keep them coming.
Mangpong.
______________
PostPosted: April 23, 2018, 7:51 am
Another possible donor upright, would be the Toyota lite-ace. But I do not know if it imported into Thailand? It would have lighter mechanicals then a pickup or Previa.
DaveW
PostPosted: April 23, 2018, 11:05 am
Another thought on the bolt-on adapters as hilighted by Driven5. They do give you the advantage being able to make your upright as tall (or as short) as you like!
PostPosted: April 23, 2018, 5:58 pm
MangPong,
Here are some notes from my build book, but first, two pictures: one of the 1989 Isuzu so that we are sure we are talking about the same vehicle, and the other of the upright (the knuckle).
Weights are: 4.0 kg knuckle, 3.75 kg hub, 4.90 kg rotor, 5.60 loaded caliper, 0.40 kg dust shield = 18.65 kg total (ugh)
Lower ball joint is Moog K9453, upper is Moog K9452 and tie rod end is Moog ES2953
Wheel Bearings are inner 'JAPAN LR NSK LN48548' and outer 'JAPAN MR NSK M12848'
Bolt circle is 6 x 5 1/2 inches (137.7mm) which is a common light truck size, but makes wheels hard to find. My truck had 14 inch steel wheels and I replaced them with 15 inch aluminum wheels (7.7 kg plus tire weight)
I did a full set of measurements on the knuckle but the distance you asked for is the distance between the outside faces of the ball-joint mounts: 166 mm, measured along the vertical axis (I did all my measurements with the knuckle at 0 degrees caster). Because the lower ball joint mount is almost as high as the spindle axis it can be challenging getting a low roll centre with this knuckle. I had to change to lower profile tires in order to get my front roll centre down to my (approximately) 65mm target (2 1/2 inches to the North Americans :-) ) BUt I chose this donor because I already owned it ....
Oh, and it is a front-steer knuckle so the usual rack position will work. But you will need to find a rack because the Isuzu Pickup had recirculating ball steering.
Don't forget that Isuzu built some small rear wheel drive passenger cars in the late 1980s and early 90s.
Warren
PostPosted: April 24, 2018, 6:20 am
daveW
I've heard of the ‘lite-ace’ here so I'll check with Toyota again - so far my local dealer has been the least interested of the main manufacturers with my search.
ngp-mike
Good point Mike - at the moment it seems I might have to accept this solution - it might certainly be the most ‘locost’... I am also concerned about what happens at the inside face of the upright, in the absence of the drive shaft - any ideas...?
Warren
Many thanks for such a comprehensive run down. At the moment my local Isuzu dealer doesn’t have these uprights in stock (probably an old model) but the scrapyard was (also) selling unofficial spares (Chinese?). It was the first place I went to, and the first upright I was offered and, as it didn’t seem ‘right’ I decided to check elsewhere, and didn’t take a photo or any measurements.
Interestingly your pickup (I think) is very common on Thai roads but your upright seems to be rather smaller than the one I was shown (and has birds nesting in the upper ball mount... lol), my memory suggests more like 8”, and I don’t recall the lower ball mounting so close to the stub axle... so I will go back for another look... but I'm also going to look for a potential donor...
The scrapyard quoted me, in poor condition: upright, hub/bearing, disc/rotor, & calliper, x2: $315...
Is there a way to convert, or use a different, hub, with just 4 (or 5) bolts - I seem to recall having seen this on LocostUSA, but cannot now locate it...
______
Many thanks to all you guys, Mangpong.
______________
PostPosted: April 24, 2018, 8:40 am
OK next suggestion :D
Would there be any old VW bugs in locate scrap yards. That would be a light wt up-right, for a three wheeler, and you could adapt disc brakes, for less then the current salvage prices for knuckle assemblies.
DaveW
PostPosted: April 24, 2018, 9:29 am
In principle, changing from a 6x139.7 hub to a more common 4 or 5 bolt hub is easy, as long as you can source bearings with OD for the new hub and ID for the old spindle. In practice, spindle length would be a real-world issue and machining might be required. I would try to chase down something with 4 or 5 bolt hubs if you have to buy it anyways.
Warren
Users browsing this forum: anduril3019 and 11 guests
