I've been looking at how to adapt smaller rotors/calipers to my solstice spindles as well. Here is what I've been able to deduce based on posts online and matching some pictures...
The solstice hub bearing assembly uses the same 3 bolt pattern as the Chevy Cobalt, which is available with a 4x100 lug pattern. This allows for far more wheel selection. I've yet to try it, but will soon be ordering the cobalt hubs to confirm fitment. At that point, you can also use cobalt front rotors which also fit under 15" wheels. As far as calipers, the cobalt caliper bracket MIGHT fit, but I have no easy way of determining this short of buying the calipers and trying. I was planning on finding a better 4 pot option and machining adapters to mount to the solstice spindles.
With all that said, I still need to get home today and double check that a 15" diameter wheel will even fit over the solstice control arms.
