pancake wrote:
Is it possible to change from rear steer to front steer by changing it the pinion or gears inside the rack?
Sure can be. Simply turn it upside down and change from Left Hand Drive to Right Hand Drive. In other words, put the driver where the passenger usually sits.
Simply put, for a typical US build, if the pinion gear is below the rack, it is meant for front steer knuckles. If the pinion is above the rack, it is for rear steer.
MV8 is right. You should design the suspension/steering as a system. There are lots of ways to skin a cat. But first you need the whole cat.
