A arm dimensions/diagrams for s10 knuckles and book frame http://locostusa.com/forums/viewtopic.php?f=5&t=209 |
Page 2 of 5 |
Author: | Tbird7 [ December 23, 2005, 1:17 pm ] |
Post subject: | ? |
How did you determine that the pinto balljoints would fit the S10/Blazer knuckle? Do you have any dimensions on the pinto balljoints? |
Author: | derf [ December 23, 2005, 2:54 pm ] |
Post subject: | |
How did I determine that, I brought the knuckle to the store, and tried it for a fit... |
Author: | datz510 [ February 27, 2006, 9:05 pm ] |
Post subject: | |
derf wrote: blazer knuckles
... The threaded tube for the heims was taken from a box of them. I don't think that lawrence engineering does mail order, but you can try. ... Any idea what these short threaded tubes are called by chassis shops? I've been searching online for the last 6 hours looking for a place that sells them, but I've had no luck. Most searches fall back to the weld-in threaded tube adapters, which isn't what I need. Any ideas? |
Author: | derf [ February 27, 2006, 9:19 pm ] |
Post subject: | |
http://www.secureperformanceorder.com/a ... ductID=715 it is weld in, never heard of attaching it any other way, but if it makes you feel better I got a chance a few months back to look at a nascar car and this is the same part that they use to build their A arms, has to be at least somewhat strong. |
Author: | datz510 [ February 27, 2006, 10:16 pm ] |
Post subject: | |
No, I mean the threaded tube sections you are using for your heims. All of the ones I have seen slip into the tube ends and are then welded to the tube end itself. Those all require a much larger tube diameter in order to work. The ones you got look like they are just threaded tubes and do not require additional tube in order to work. I need some of those in 5/8" and 7/8", but cant find them anywhere. These are the only kinds I can find: |
Author: | derf [ February 27, 2006, 10:39 pm ] |
Post subject: | |
yeh they were just sitting on a shelf in the store. You can make your own if you know how to thread tube, but I'm not sur where they buy theirs, I'll look around while I'm at work tommorrow, i know ive seen it online before |
Author: | RebelGT [ February 28, 2006, 9:17 am ] |
Post subject: | |
those inserts are called: weldable tube ends you're looking for: female threaded rod you can get it from mc master carr, your local steel supply, or a race shop. |
Author: | emohn [ February 28, 2006, 9:33 am ] |
Post subject: | |
RebelGT wrote: those inserts are called: weldable tube ends
you're looking for: female threaded rod you can get it from mc master carr, your local steel supply, or a race shop. The largest size that I could find from McMaster Carr was 1/4"-20 threaded. That's smaller than the rod ends I had planned on using. Any specific sources you might be willing to divulge? Chassis Shop doesn't have it, and they typically have everything like this. I could just find some tube of the appropriate ID and OD and tap the tube, but if I can purchase the right thread size and pitch off the shelf, then it's all the better. -Erik |
Author: | RebelGT [ February 28, 2006, 10:55 am ] |
Post subject: | |
I did a quick search on McMaster, this is for round, I know they have Hex as well. Steel Zinc-Plated 10-32 3/4" 6" 6516K51 $6.46 Steel Zinc-Plated 10-32 3/4" 12" 6516K52 7.83 Steel Zinc-Plated 1/4"-28 1" 6" 6516K53 6.71 Steel Zinc-Plated 1/4"-28 1" 12" 6516K54 9.15 Steel Zinc-Plated 1/4"-28 1" 18" 6516K55 8.51 Steel Zinc-Plated 5/16"-24 1-1/4" 6" 6516K56 6.91 Steel Zinc-Plated 5/16"-24 1-1/4" 12" 6516K57 8.26 Steel Zinc-Plated 5/16"-24 1-1/4" 18" 6516K58 12.05 Steel Zinc-Plated 5/16"-24 1-1/4" 24" 6516K59 10.17 Aluminum Plain 3/8"-24 1-1/4" 6" 6516K61 6.91 Aluminum Plain 3/8"-24 1-1/4" 12" 6516K62 7.83 Aluminum Plain 3/8"-24 1-1/4" 18" 6516K63 8.71 Aluminum Plain 3/8"-24 1-1/4" 24" 6516K64 9.63 Aluminum Plain 3/8"-24 1-1/4" 30" 6516K65 10.51 Aluminum Plain 7/16"-20 1-3/8" 6" 6516K66 7.17 Aluminum Plain 7/16"-20 1-3/8" 12" 6516K67 8.20 Aluminum Plain 7/16"-20 1-3/8" 18" 6516K68 9.31 Aluminum Plain 7/16"-20 1-3/8" 24" 6516K69 10.17 Aluminum Plain 7/16"-20 1-3/8" 30" 6516K71 11.51 Aluminum Plain 7/16"-20 1-3/8" 36" 6516K72 12.57 Aluminum Plain 1/2"-20 1-1/2" 6" 6516K73 7.60 Aluminum Plain 1/2"-20 1-1/2" 12" 6516K74 9.17 Aluminum Plain 1/2"-20 1-1/2" 18" 6516K75 10.37 Aluminum Plain 1/2"-20 1-1/2" 24" 6516K76 11.97 Aluminum Plain 1/2"-20 1-1/2" 30" 6516K77 13.17 Aluminum Plain 1/2"-20 1-1/2" 36" 6516K78 14.74 Aluminum Plain 5/8"-18 1-5/8" 12" 6516K79 10.77 Aluminum Plain 5/8"-18 1-5/8" 18" 6516K81 12.94 Aluminum Plain 5/8"-18 1-5/8" 24" 6516K82 15.11 Aluminum Plain 5/8"-18 1-5/8" 30" 6516K83 17.29 Aluminum Plain 5/8"-18 1-5/8" 36" 6516K84 19.49 Aluminum Plain 3/4"-16 1-3/4" 18" 6516K85 15.74 Aluminum Plain 3/4"-16 1-3/4" 24" 6516K86 18.80 Aluminum Plain 3/4"-16 1-3/4" 30" 6516K87 25.06 Aluminum Plain 3/4"-16 1-3/4" 36" 6516K88 25.57 Another option would be to just get a link tube and chop it in half. http://www.hrpworld.com/index.cfm?form_ ... on=product http://www.hrpworld.com/index.cfm?form_ ... on=product here's another option from mcmaster, a Connecting nut. Grade 5 3/8"-24 9/16" 17/32" Not Rated 90565A320 $3.41 per Pack of 25 Grade 8 7/16"-20 5/8" 39/64" Not Rated 90565A325 6.45 per Pack of 25 Grade 8 1/2"-20 3/4" 11/16" Not Rated 90565A330 8.13 per Pack of 25 Grade 8 9/16"-18 7/8" 49/64" Not Rated 90565A333 3.71 per Pack of 10 Grade 8 5/8"-18 15/16" 27/32" Not Rated 90565A335 4.65 per Pack of 10 Grade 8 3/4"-16 1-1/8" 1" Not Rated 90565A340 7.60 per Pack of 10 Grade 8 7/8"-14 1-5/16" 1-5/32" Not Rated 90565A345 5.73 per Pack of 5 Grade 8 1"-14 1-7/16" 1-5/16" Not Rated 90565A350 8.39 per Pack of 5 Grade 8 1-1/4"-12 1-13/16" 1-5/8" Not Rated 90565A355 5.54 per Pack of 1 Grade 8 1-1/2"-12 2-3/16" 2" Not Rated 90565A061 20.16 per Pack of 1 Not Rated 1/4"-20 1/2" 7/8" American Society for Testing and Materials (ASTM) 90654A305 1-9 Each 10 or more 35.15 Each 29.87 Each Not Rated 3/8"-16 11/16" 1-3/4" American Society for Testing and Materials (ASTM) 90654A311 1-9 Each 10 or more 29.44 Each 24.92 Each Not Rated 1/2"-13 7/8" 1-3/4" American Society for Testing and Materials (ASTM) 90654A317 1-9 Each 10 or more 31.09 Each 26.42 Each Not Rated 5/8"-11 1-1/16" 2-1/8" American Society for Testing and Materials (ASTM) 90654A323 1-9 Each 10 or more 33.69 Each 28.63 Each Not Rated 3/4"-10 1-1/4" 2-1/4" American Society for Testing and Materials (ASTM) 90654A329 1-9 Each 10 or more 35.31 Each 29.99 Each Not Rated 7/8"-9 1-7/16" 2-1/2" American Society for Testing and Materials (ASTM) 90654A334 1-9 Each 10 or more 36.26 Each 30.81 Each Not Rated 1"-8 1-5/8" 2-3/4" American Society for Testing and Materials (ASTM) 90654A340 1-9 Each 10 or more 46.24 Each 39.30 Each Not Rated 1-1/4"-7 2" 3" American Society for Testing and Materials (ASTM) 90654A346 1-9 Each 10 or more 53.94 Each 45.84 Each Not Rated 1-1/2"-6 2-3/8" 3-1/2" American Society for Testing and Materials (ASTM) 90654A351 1-9 Each 10 or more 62.55 Each 53.16 Each |
Author: | emohn [ February 28, 2006, 11:59 am ] |
Post subject: | |
The aluminum and zinc-plated (I think) probably won't work, as I intend to weld them to mild steel tubes. The hex stuff could probably work, but I'd really like to find something like what derf used right off the shelf. |
Author: | calvin [ February 28, 2006, 2:10 pm ] |
Post subject: | |
Dale got his from this place: http://www.midwestcontrol.com/catdispla ... php?pg=225 I think he got the 1/2" ones. |
Author: | datz510 [ March 23, 2006, 1:59 pm ] |
Post subject: | |
I still havent been able to find a source for the weldable threaded tubes for the rod ends. Have been looking for over a month now. None of my local race shops have seen anything like it. |
Author: | datz510 [ March 23, 2006, 11:21 pm ] |
Post subject: | |
As a last resort today, I went to a machine shop over lunch to get some threaded tubes made.. ended up being about $150 for 4 of them... labor isnt cheap. Got four 5/8"-18 RHT ends in two 1" di x .200" x 3' sticks. I think it will work out a little better this way though, since these are for my rear lower arms, I can have my arm ends threaded without creating potential weaknesses by butt welding small peices. |
Author: | calvin [ March 24, 2006, 4:50 pm ] |
Post subject: | |
What am I missing.. It looks like people gave you several sources for these things in this thread for less than $5 each.... Is there something wrong with those? |
Author: | datz510 [ March 24, 2006, 5:37 pm ] |
Post subject: | |
I'm looking for threaded DOM tube, not weld-in inserts.. they are different. If you look at the parts that derf used, they are short sections of tube that are threaded internally and are steel, so they can be welded to your A-arms. With the tight clearances I have in my IRS bracketry, I cant use the weld-in bungs, since the tube typically must be quite a bit bigger than the threaded end, due to the extra material that must go inside the tube end. Larger tube would interfere with the travel of my lower A arm. If you look at this pics of derf's arms: The little peices that the heims thread into.. thats what I needed. After looking for them for a month, I ended up having DOM tube machined with threaded ends to accept the heims, which will actually work better for me, but definitely wasnt the cheap route. |
Page 2 of 5 | All times are UTC - 5 hours [ DST ] |
