It is currently May 18, 2024, 2:42 pm
PostPosted: May 29, 2021, 8:38 am
Had a good find today for a project I am working on, and most projects into the future.
I have wasted countless hours looking for a good bush for control arms and trailing arms over the years, there is so many of them, but the car manufacturers seem hell bent on not using a standard sized tubing for the casing, it's like it's written law, and that's the issue, the casing.
Well, here is an answer for many, the Isusu DMax, which is also known as the Chevrolet Colorado (and Holden), 2004 to 2012, 2WD upper control arm bushes. It's on the harder side for performance for most of our lighter vehicles.
My tube here is stock 48mm x 2.5 wall, but you could grab 1.9" or 2" tube, with thicker wall and turn the inside to size, easy job. Also note that a World standard for scaffolding tube is 48mm x 3.2 wall.
My tube is only a light hammer tap fit, which is too loose, but after welding it into place, it should shrink it the casing to a press fit. Hope it helps someone :-)
PS: (rounded)
32 = 1.25"
43 = 1.7"
45 = 1.77"
PostPosted: May 29, 2021, 11:11 am
Hey Cheap, I got nothing. I just wanted to say that I noticed that it's been over 2 years since your last post. Welcome back! We missed you. At least I did.
PostPosted: May 29, 2021, 1:38 pm
My wife misses me as well, but as I'm getting older I am getting slower to duck, was close last time...
PostPosted: May 29, 2021, 3:25 pm
Bah-Rump-Bump!!! :D :D :D
PostPosted: May 30, 2021, 8:36 am
Currently rather expensive at $15/pair for one uca.
I've yet to find anything more cost effective than triumph spitfire sets in nylon for $45 for eight bushes with inner sleeve; enough for four control arms. Can't make them that cheap with the cost of nylon and steel. Original replacement spitfire bushes cost less than the nylon. These are the bushes spec'd in the Champion book.
Pipe is another source for matching shell ID to available bushing stock without turning.
PostPosted: May 31, 2021, 3:04 am
I can't find your detailed post on this with pictures, giving bush sizings, what size tube to use etc.
PostPosted: May 31, 2021, 8:10 am
Probably next your details on Chinese cv half shaft specs I asked for a few years ago? :lol:
Wanna trade? I doubt it.
PostPosted: May 31, 2021, 3:48 pm
I used Energy Suspension part number 9.9107G. These bushings fit perfectly inside a 1.5” OD, 0.120” wall DOM tubing, and use a 1/2” bolt.
PostPosted: May 31, 2021, 4:30 pm
Cool bananas, good info, thanks.
I need to use 'off the shelf' production bushes because I will be making a few hundred of them, and they need to be able to be sourced and purchased with ease both now, and later on.
PostPosted: May 31, 2021, 9:33 pm
Cheap, following mainlandboy's post, I found this page listing all of their universal parts by size. it may help you find one if his part number is not to your liking.
https://www.energysuspensionparts.com/e ... shings.asp
PostPosted: May 31, 2021, 10:05 pm
I suspect that the Energy Suspension universal bushings will be available off the shelf for a very long time, perhaps longer than OEM replacement bushings for a specific car make/model.
PostPosted: June 1, 2021, 11:29 am
Well the ES bushings ain't now, and I suspect they never will be in Asia, Europe, UK and Australasia :-)
Anyway, good thread, I know people do get headaches looking for bushing answers, and it's not a competition, everyone benefits from the input :-)
Users browsing this forum: Google [Bot] and 19 guests
