It is currently Thu May 23, 2013 1:41 pm
Post new topic Reply to topic  [ 114 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
 Post subject: Miller's Locost +442 Miata
PostPosted: Sun Oct 03, 2010 7:33 pm
This project started a 6 months ago when I started looking for a donor. In mid August I found a 93' Miata, after driving it for a month it was time to start.
I plan on using as much of the Miata as possible, including the rear subframe, to build the 442.
Here are some pics of the before and after donor dismantle.
File comment: wasn't this clean when I started
File comment: my wife wanted to keep it this way
Past toys: 68'Austin Mini, 82' VW sand rail
Build Log:
http://www.locostusa.com/forums/viewtopic.php?f=35&t=10995
 Post subject: Re: Miller's Locost +442 Miata
PostPosted: Sun Oct 03, 2010 7:52 pm
Here are some recent pics,
I am using a freinds welder until I get one.
Which welder are you guy's using, I been watching craigslist fo a good deal, 120v. or 220v ? miller, lincoln, hobart, century? What do ya think?
Build Log:
PostPosted: Sun Oct 03, 2010 8:54 pm
Nice donor!
I bought myself a Lincoln SP 125+ off craigslist. I don't really need anything bigger than that at home for this project, and I only have 110V available to me currently. I think it's also easier to use a smaller welder: they take up less space, they're usually cheaper, and for our project, the smaller wire (.023, .025) makes for a much nicer welding experience on thin metal.
-Matt "I wish my Miata had leather!" Rogers
PostPosted: Thu Oct 07, 2010 7:13 pm
Found a Hobart 140 on CL with bottle and cart for $300, its only a few years old and so far its working good, I just need a little practice. I started with .030 wire but switch to .023, heat setting at 3 and wire speed at 45, it seems to work a little better on 16 g. tubing, Any other suggestions ?
Build Log:
PostPosted: Thu Oct 07, 2010 7:32 pm
Practice, practice, practice.
Oh, that and clean every tube before you weld it.
Go get'em!
Jonathan
PostPosted: Fri Oct 08, 2010 11:02 am
I was told that a 220v welder with 175 amps is needed to build a Locost. Sounds like that isn't the case. The 1" frame tubes are 16 gauge, right? Sounds like the smaller 125-140 amp welders handle this just fine.
PostPosted: Fri Oct 08, 2010 11:23 am
You are correct. Just about everything on a Locost can be welded using a 110v mig or tig welder. 220 would be great to have because of the ability to do other bigger stuff, but many here have built their entire cars with smaller welders.
Jonathan
PostPosted: Fri Oct 08, 2010 11:37 am
Something I've found with my welder (Lincoln power mig 180) and every other small mig welder I've used, is that the chart inside for the settings is off a bit to the cold side. To get good penetration with well fitted joints, I like to have my welder one or 2 settings hotter than the recomended.
Kristian
PostPosted: Fri Oct 08, 2010 4:20 pm
Turbo,
That is exactly what I found out, I'm using the 3rd heat setting and running at 45 on the speed dial. This gives me good penetration,
Feels good to make it 3-D,
File comment: Does your build table look a mess like this
Build Log:
PostPosted: Sun Oct 17, 2010 8:54 pm
Now that I have the rear subfame tacked in place, I'm ready for the engine mounts.
It's finally starting to look like something. :D :D
I was going to use the rear stock shocks but sounds like everyone is upgrading to something else. Where does everyone get there shocks? How much money are we talking?
File comment: rear subframe
File comment: Rear subframe
Build Log:
PostPosted: Sun Oct 31, 2010 8:32 pm
I have been busy, just not very busy with the Locost. but here are a few pics.
I hope my engine doesn't set to tall, the sump hangs down about an 1 1/4".
The next item on the list is the transmission tunnel, then more diagonals, and soon wil be working on the front suspension whenever I get a quote back from Kinetic.
What is everyone using for shocks (spring rate,diameter, and length), is most people getting there supplies from Kinetic (front suspension, fiber-glass). I'm thinking of using brake/clutch assembly similar to what Chetco installed.
File comment: Rear diff
File comment: Tranny mounts
File comment: Motor is in
Build Log:
PostPosted: Sun Nov 07, 2010 9:48 am
A few updates,
Next on the list is more braceing, finishing the rear tubes, monting points for roll cage, seat mounting, and front suspension when I scrape together some money.
File comment: going to be a tight fit for the hood
Build Log:
PostPosted: Sun Nov 07, 2010 9:12 pm
The first of many minor setbacks, With only an inch of clearance between the tire and rear diagonal brace, after I get some shocks I will modify this.
Build Log:
PostPosted: Mon Nov 08, 2010 2:16 am
That might still be doable. When the suspension is in full bump, how close does it get?
PostPosted: Mon Nov 08, 2010 11:39 am
Locostering Legend
Use longer wheel lugs and spacer plates or get wheels with less offset.
Users browsing this forum: seattletom, watty and 1 guest
