It is currently Thu May 23, 2013 6:56 pm
Post new topic Reply to topic  [ 194 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13
 Post subject: Re: Single seater BEC middy, GSX-R 1000 power
PostPosted: Mon Jan 23, 2012 11:38 am
Something like this and time for a new phone I think.
PostPosted: Mon Jan 23, 2012 7:44 pm
hmm, interesting... I do not have to deal with servo which makes things easier..
might investigate using a longish pushrod and placing the clutch master under the seat.. :)
In other news, think I can use eclipse/colt gti inner CV's as a direct fit into my diff (with a custom housing for the diff of course).... Talked to some local mitsubishi guys over here and will take a look at some used CV joints they have, next week.. This would be a great way of solving my need for custom stub shafts..
PostPosted: Tue Jan 24, 2012 9:58 am
Have you ever determined why someone would pick floor mounted pedals over hanging ones or vise versa? I am trying to determine this for my ride. Is it just what fits best? Comfort?
My build: viewtopic.php?f=18&t=13096
PostPosted: Tue Jan 24, 2012 10:50 am
lower center of gravity. ?:)
I can't fit overhanging pedals in my frame...
PostPosted: Tue Jan 24, 2012 11:00 am
I will put hanging pedals in mine because if I use floor-mounted the master cylinders will interfere with my stock header, which just fits ... the Autech SR20DE header is just too beautiful to throw away.
Warren
PostPosted: Tue Jan 24, 2012 1:05 pm
Yup.
Personally I never liked the feel of floor pivoted but I have no choice.
PostPosted: Tue Jan 24, 2012 5:06 pm
The clutch feel bugs me, with brake I have no problem.. :)
as far as packaging is concerned, floor mounted pedals with cylinders mounted under the drivers feet is unbeatable,.. but sadly not available easily..
PostPosted: Wed Jan 25, 2012 3:00 am
Try this place, I have delt with them and service is good.
http://www.obpltd.com/obp-shop/race-car ... or-mounted
http://lmpaustralia.forumotion.com/t205 ... -melbourne
PostPosted: Wed Jan 25, 2012 5:33 am
interesting supplier... thanks for the link.. :)
PostPosted: Wed Jan 25, 2012 9:17 pm
I had the overhung from them (second hand) installed in my old saab rally build since I couldn't heel toe the stock pedals well. They worked great and I never had any issues. (except when i bled the system, now under the dash, and spilled fluid all over the inside of the car)
PostPosted: Thu Jan 26, 2012 12:26 am
because rally car.
PostPosted: Thu Jan 26, 2012 11:19 am
Kiki, here's an older way I was going to go with - note the square box pedal shaft has a round tube inside that the balance bar goes through and can pivot in, functional and dirt cheap to build.
PostPosted: Thu Jan 26, 2012 6:28 pm
what master cylinders are those.. Pivots at the end of the cylinder look much better than the usual attachment..
PostPosted: Fri Jan 27, 2012 12:54 am
Just some common clutch cylinders with some female thread brass heim joints.
Otherwise they come standard with typical clevis joints.
