Had some free time this weekend, so I focused on building the mounts for the front cycle fenders. I looked around on the forums at other designs and decided to scrap the aluminum ones I started to build a while back. I felt they would not be strong enough to hold up long term and decide the couple of pound added by doing them in steel may save me from remaking a couple months down the road.
I kept it pretty simple. Two tabs with ½ tubing bent in 90 degrees welded to them. Then to straighten up the assemble I triangulated the two pieces. Doing my scientific pulling and tugging test it seems fairly strong. Then for each wheel assembly I made up four tabs to be welded onto the tubes and taped them for 10-32 screws that will come through the top side of the fender with rubber washers and Locktite.
The photo show cap head screws, but I’ll change them to either button heads with rubber washers to protect the paint.
Sunday night I then put a couple coats of high build primer to smooth out the fiberglass. These parts where from Cloveland Motorsports and the gel coating was not a smooth as the rear fenders and scuttle I picked up from Kinetics. Nothing two coats of high build primer and some wet sanding won’t fix. Last night I wet sanded them down with 500 grit, tonight some sealer primer and paint. I'll post pics when done.
