It is currently April 18, 2024, 11:13 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Locost Buggy build
PostPosted: December 20, 2013, 12:44 am
L&R shoulders?
PostPosted: December 20, 2013, 12:50 am
Yep, my bad. Need to spell check more offen. :oops: rotator cuff's :ack:
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 2, 2014, 3:56 pm
Need more photos,Langan !
You got me thinking maybe a buggy with my AWD idea mite work?
Also was thinking a pull rod front mite work with the Subaru front upright?
Thanks,Randy :cheers:
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 2, 2014, 9:44 pm
Had no idea you were building AWD? Or are you just dreaming of next build? I do hope you do come up with Subaru AWD maybe mid engine. I only think pull rod suspention is worth it when nothing else will do. To many parts to rattle
PostPosted: January 2, 2014, 10:05 pm
Mostly thinking for now. 8)
Keep looking at the parts and would like to find a way to use them. :shock:
Now just need to come up with a way to mount a coil over of to the side? :oops:
Would be fun to have a AWD Manx/style car?
What is the Max. wheel base for the Manx body? Think it was 14" less than the Bug?
Thanks,Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 2, 2014, 10:09 pm
Na, the coilover would need to move with the steering. What was I thinking. Not! :ack:
Dam struts. :BH:
Looks like I'm back to a pull rod. :oops:
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 3, 2014, 12:27 am
Yes Manx 80" but the 4 seater body is 94 and the wheel well are very generous. Mine wheel base is 83" 2" longer in rear and 1" in front. Its just for fun and a simple build so I can complete something. I really need to get back to my other builds.
My biggest problem is I am not home much and like most of us always building in my head and the fun is in the hunt. I loose momentum and focus when not at home.
PostPosted: January 3, 2014, 10:13 am
Thanks for the info!
I think I have found the answer. Rocker arm!
Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 3, 2014, 11:12 am
Yes that let's you put coil covers just about anywhere. What build?
PostPosted: January 3, 2014, 12:53 pm
BUILD? We don't need no stinking "BUILD". :lol:
Long story,I got a RC/Desert Racer for the Granddaughter. Was looking at and the front end and it looked like the Subaru stuff. Got me thinking ! :shock: If you ask the Wife, that is a bad thing? :ack:
Then you posted the Buggy build, and more ideas! :cheers:
Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 28, 2014, 12:45 am
PostPosted: March 8, 2014, 8:36 pm
Some up dates
Sitting on ground 2.75 and 3.25 ride higth
Brakes,clutch,gas,shifter and steering hooked up
And some stock headlight 24" to center of bulb
PostPosted: March 8, 2014, 9:17 pm
Very Sweeeeeet! :cheers:
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: March 9, 2014, 8:24 am
Nice buggy. Are you going to fit the side panels or leave it open? How did you pin the drive extension to the shift rod at the transaxle? I've considered using those as swivels but assumed the hardened steel would be a pain to drill.
Here are a couple pics of my favorite buggies.
PostPosted: March 9, 2014, 11:16 am
Great pictures
The shifter universal was a 1/2 drive Craftsman it machined more like chrome molly. The rear one was better it used split pins for joints the front one is new and not made as nice. Welded with SS rod. Time will tell how well it holds up.
