It is currently May 14, 2024, 5:31 pm
Post new topic Reply to topic  [ 483 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 33  Next
PostPosted: May 13, 2017, 12:37 am
Fabbed up and located the windshield stanchions. Made cardboard template for scuttle.
PostPosted: May 13, 2017, 3:55 am
Moving right along, Great progress Perry!
Larry in Seattle
PostPosted: May 14, 2017, 4:50 pm
Amen on the black paint. I heard others complaining about that choice, which they made and regretted, and the fact that your can't see cracks, etc., on the black frames. I'm going with a glossy medium gray myself because of it.
Well, Perry you may have built 3 Locosts before I finished my first, but by God Almighty, you won't get number 4 completed before mine is rolling around on the ground and running. :wink: I think I'm going to have mine done around the end of this year. :yay:
I don't think my neighbors believe a finished car will come out of my garage before I come out of it in a coffin. :mrgreen: One of the most surprising things about my build is that not one kid in our neighborhood has ever stuck his or her head inside the garage to ask me what I'm building. And, this is California. I work with the big door open most days. In fact, me working on the Locost mock-up is actually part of the Google Maps "street view" for our house. Building cars is practically a genetic imperative in this state. However, it looks like smart phones and video games have replaced the core interest of young people once had in cars here - too bad.
Congrats on nearing a close with this one, Perry.
PostPosted: May 14, 2017, 10:42 pm
No truer words are spoken.
Millennials and up and coming Gen Z (The Founders) are (1) loosing the ability to communicate verbally person to person in the flesh, (2) are loosing the ability to use penmanship, and (3) are failing to use proper spelling and grammar when communicating on smart phones texting or typing.
Just my 58 year old opinion
PostPosted: May 15, 2017, 8:57 am
I work in the bicycle industry and we feel that the same factors are responsible for some of the softening of the industry in the last several years.
-Keith
PostPosted: May 15, 2017, 10:37 pm
Out to the shop for a bit today. Transferred the construction paper scuttle pattern to aluminum. Cut out scuttle aluminum, cut out wiper arm drive shaft holes, marked and drilled out defrost holes. Measured and marked rivet locations, strapped aluminum sheet to scuttle frame, drilled and cleco'd.
Some pics.
PostPosted: May 15, 2017, 11:55 pm
With all those Clecos, it looks like a steampunked porcupine!
Nice work, looks good!
http://zetec7.webs.com/
PostPosted: May 17, 2017, 12:59 am
Thanks for the kudos, zetec7!
Out in the shop for a bit today. Removed scuttle aluminum to clean up hole burrs and swarf. Reattached with Cleco's every second hole and riveted. Couple of pics of riveted scuttle.
Made construction paper template of rear panel. Transferred to aluminum sheet and cut out. Test fit to frame several times before clamping, drilling, and Cleco's.
Removed rear panel to clean up hole burrs and swarf. Installed rear panel w/Cleco's, using my slapper tools formed panel around top 3/4" tubing.
Once happy with the final fit, alternately removed Cleco's and riveted
PostPosted: May 17, 2017, 3:31 am
That looks EXCELLENT!! Well done, sir!! :cheers:
PostPosted: May 17, 2017, 9:51 am
Yeah, very nice job, Perry, plus it's sort of a mini-tutorial. The detail around the gas filler cap location is nice too. How'd you do that?
Also, did you use a sheet metal brake to bend the rear panel around the bottom of the chassis before placing it, or just bend it in place after you were happy with the overall fit?
Are the holes on each side the locations where you will mount the fenders?
PostPosted: May 18, 2017, 12:05 am
[quote="Lonnie-S"]The detail around the gas filler cap location is nice too. How'd you do that?
I have a piece of 3/4" plywood that has various shapes cut from it, then the shapes are beveled back about 1/2". Just lay the aluminum sheet on top and slap it to shape the bevel around the hole. This eliminates any kind of "oil canning" the hole may have induced.
I clamp the sheet to the edge of the build table between a piece of 3/4" x 2" by however long board. Then I use the slapping tools to form the bend. The only bend I form on the frame is the top bend of the side panels. I use the frame in the same manner as the build table.
Thats right, 3 holes are fender mount rivnuts, and the 4th hole is for the tail light wiring./quote]
Went out to the shop after supper and constructed the side panel pattern from construction paper. Some pics.
PostPosted: May 19, 2017, 12:56 am
Spent a bit of time in the shop today. Transferred pattern to .040" aluminum sheet. Cut it out and cleaned edges.
used my bevelling jig/tool to bevel holes around control arm pivots.
Before forming a 90 I measure back 1/4" from the edge and slap a fold in the aluminum. This ends up keeping the edge firmly against the frame when riveted down and looks cleaner, without doing this the finished edge can be wavy. Clamped the sheet to the table and slapped/formed the lower 90.
The I turn the sheet and reclamp to overbend the 90, this keeps it tight to the frame.
Then measured and set rivet hole dimples.
Test fit the sheet to the frame. When I was happy with the fitment I drilled and cleco'd the lower 90.
Then I clamped backup boards to the sheet/frame and slap formed the top 90. Measured and marked rivet hole locations, dimpled them, drilled and cleco'd.
Tomorrow just have to remove side panel, debur holes, clean swarf, and get ready for final assembly/riveting. The drivers side will be the same with the exception of the exhaust pipe hole and muffler br@cket holes.
PostPosted: May 19, 2017, 11:15 am
Thanks for the details, Perry. Both books, Champion & Gibbs, are a little short on the how-to part of the body panels.
PostPosted: May 19, 2017, 5:52 pm
What do you mean by measure 1/4" back and "slap a fold"?
PostPosted: May 19, 2017, 6:10 pm
He meant slap back for a 1/4 fold. :rofl:
Great work, Perry. How's that book writing course coming along?
Martin
My build log:
My build video:
