It is currently January 23, 2018, 2:01 am
PostPosted: August 10, 2017, 1:13 am
Have the bones of a Laballa frame/kit - need info...
The front a-arms have RH 5/8-16 weld in inserts & the front suspension pod (subframe) is already set up w 3/8" holes in the brackets. Not finding much in the way of 3/8" by 5/8-16 Heim or rod ends - I'm thinking maybe to drill out brackets for 1/2" instead. Any body want to weigh in? Brackets are about 1-1/2" ID so maybe rod end w rubber bushing instead? I'll post pics if anyone wants a visual. Going to start to mock up chassis to put under a classic mini body. Have an MR2 donor out there. Accomplices want to do FWD Honda or RWD 6spd DuraWhatever in the Mini body. I plan on at least getting the Laballa frame rolling so someone will make a decision & trade me something I can use
PostPosted: August 10, 2017, 2:11 am
Is there enough room between the brackets to put high misalignment spacers in with the rod ends? There are high misalignment spacers available to bring both 1/2 and 5/8 ball bores down to 3/8.
PostPosted: August 10, 2017, 9:51 am
^^^^^^^^^^^ This ^^^^^^^^^^
I have on more than a few occasions used sleeves or stepped spacers to enable the use of larger bearing rod ends with smaller hardware.
Feels like I'm on the last train,
rolling on cracked wheels,
and Hillary is the engineer!
