It is currently May 12, 2024, 12:42 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
PostPosted: December 25, 2007, 3:21 pm
I posted this in the electrical section but then thought this was more appropriate, sorry about that - mods, you can remove the other thread if you want.
Has anyone done a carb conversion on a 1.8 miata engine? We're trying to do away with the insanely large wiring harness and thought it might be neat to run an old school setup. Possibly also a distributor if we can. If not carb and distributer, then we'll do a carb conversion and run an aftermarket ignition system.
If anyone has done either both conversions or just a carb conversion with an aftermarket ignition system and can give us some direction, it would be awesome.
Thanks,
217.
Project 217 - Started 8/4/07 Build Thread Here!
PostPosted: December 27, 2007, 8:25 pm
It's been done a few times, mostly by people in Japan.
The first question is why. You'll never get a carb setup to work as well as a good fuel injection setup, although some people are more comfortable working with carbs because they're easier to understand. On a Miata, there's no good reason to pull the fuel injection or the distributorless ignition. On a Locost, there's a bit more reason although it will (ironically) cost you more money.
For mounting the carbs, use the same adapters that people are using for homebrew individual throttle body setups. I have one from Boig Motorsports, but they're more expensive than some others. TWM can probably help out as well. Regardless of source, they'll typically have a Weber flange on the end.
For a distributor, that's easy. Mazda (and Ford, and Kia) used a dizzy on longitudinal applications. It plugs right in to the Miata head where the cam angle sensor is now. Then you'll have managed to downgrade your modern fuel and ignition system to the same level of sophistication as my 1960's Land Rover :wink:
PostPosted: December 27, 2007, 8:59 pm
It's been done a number of time - but rarely for street cars. SCCA Production cars required carbs until recently.
Do a search on clubroadster.net for a couple carb conversions. IIRC, there was at least one on miata.net also.
PostPosted: December 27, 2007, 9:27 pm
Of course, E Production cars. I forgot about that, although that's why Boig Motorsports sells the adapter that's on my desk. F Production Miatas run fuel injection and DIS though.
PostPosted: September 16, 2017, 12:11 am
Yah, I know, resurrecting the dead. :ack:
This thread came up when I began searching for a Weber manifold to fit a Miata 1.8.
Glad to find it but strongly disagree that going to Webers and a distributor is throwing anything away except unnecessary complication.
Actually I think I can keep the distributor-less ignition fairly easily.
But that oversize and overly complex FI needs to go away for my intended use.
Tried to search BOIG Motorsports but all I found there were Cobra clone parts.
So still trying to locate a Weber intake.
Might be able to mill one from billet but it may be expensive to get the CAD done.
PostPosted: September 16, 2017, 12:21 pm
If you still want to go carb maybe get one of the itb manifolds they sell and get four individual bike carbs.
Build on
Chris
PostPosted: September 18, 2017, 4:11 pm
I wouldn't mill one, but I might try welding one, like a typical British intake manifold. A flat flange could be water-jet cut from 3/16 or 1/4" sheet. Weld on four short pipes, a transverse tube connecting the pipes, then a carburetor flange (or two) onto that.
PostPosted: September 20, 2017, 9:15 pm
I am currently doing this very same thing, but on a 1.6. I am using 40 DCOE's and my plan is to keep the stock ECU to run the ignition only. I was lucky enough to find a Mazdaspeed manifold on EBAY (p/n 0000-06-5301) which greatly simplified things. I have a book called Mazda Miata Performance Handbook, by Norman H. Garrett III, in which he explains a way to "trick" the ECU into thinking it still sees an AFM or MAF in the case of the 1.8. If I cant get that to work Ill do a megajolt. He also gives a base line for jets and chokes. Im going to start with his suggestions and see what happens.
PostPosted: September 20, 2017, 9:32 pm
Thanks for the tip, all I found were pics of TWM but no current listing.
PostPosted: October 28, 2018, 5:19 pm
Two weeks ago I started this set-up for the first time and it ran like a top. Fired on the first turn of the crank. The idle speed and mixture were even almost-close. I used the stock Miata ECU and stripped everything out of the harness that isn't needed to run the ignition. I built the "black box" from Norm Garretts book to flip the signal from a MAP sensor. If anyone is interested I will post the detail of the ECU wiring. Now I need to shift my focus eleswhere so I can start to tune at other-than-idle.
PostPosted: October 29, 2018, 3:52 pm
https://danstengineering.co.uk/index.ph ... uct_id=627
They're out there, now.
http://zetec7.webs.com/
PostPosted: October 29, 2018, 6:23 pm
How about some pics of your work? Where did you get the circuit components? Do your carbs have the parts Norman suggested?
The 89 or so 323 turbo distributor should fit also. It has fly weights and vac advance. I saw Norman fit SU carbs too.
PostPosted: October 29, 2018, 8:58 pm
MiataV8, sure. This is the mess I started with:
The entire harness from a ‘91 Miata. I got it running and everything worked. I wanted to have a solid baseline for the timing, to eliminate at least one variable
PostPosted: October 29, 2018, 9:07 pm
After many hours of studying Miata wiring diagrams and troubleshooting books I figured out what I knew I needed, what I might need and what I definitely didn’t need. Then I just started cutting. In the end there are only 9 wires left at the ECU. The rest of the bundle is for lights, switches and gauges.
PostPosted: October 29, 2018, 9:10 pm
Tell us more!
Exactly WHICH nine? :D
Schematic?
