It is currently February 24, 2020, 1:33 am
Post new topic Reply to topic  [ 208 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 14  Next
PostPosted: February 12, 2019, 8:19 pm
I built trusses once and decided that I would buy them thereafter. Talk about a picky job to build them, even with a template on my workshop floor. I got a surprise at plan approval for my building permit. The inspector couldn't approve trusses unless they were manufactured or my drawings were stamped by a PE. I'm a PE, but spent most of my career in government. Approving my truss drawings was the only time in my career I used my PE stamp in anger. :-)
Warren
PostPosted: February 13, 2019, 8:57 am
Warren, can you verify my garage door header plan? I'm building the same thing that was in my SC garage.
Doubled 2x12 with 1/2 inch OSB spacer glued and nailed. 5 16D nails every 16 inches
Then nailing a 2x4 on the bottom of the assembly with 2 nails every 16 inches.
I've called Code Compliance and no one seems certain. They said nearly everyone is using LVL headers to save time.
PostPosted: February 13, 2019, 10:25 am
Steel I-beams. Yeah, let the hurricanes blow THAT down! (male grunting noises).
At least that's my plan for when I hit the lotto...
PostPosted: February 13, 2019, 10:45 am
Trusses arrived 20 minutes ago. Came with PE stamped framing plan, design loading details, BCBI-B1 installation and bracing details, a TWO, yes TWO carpenter pencils.
PostPosted: February 13, 2019, 12:24 pm
What? No Sharpies? Or maybe the truss company put Sharpies in there, but they escaped, leaving the pencils behind. Sounds like something a bunch of rat-b@stard Sharpies would do... :mrgreen:
PostPosted: February 13, 2019, 12:34 pm
tommy, I can't say for certain. I am not a structural engineer. However I did some searching. I think your 2x12's with OSB is not a good choice. I've read some reports of built up 2x12 beams of a similar span used on a gable end like yours and they have sagged in short time.
Here is one reference I found for span vs supported roof. It looks like glulam is the recommended way. Size depends on your building code's required snow load.
http://www.southernpine.com/app/uploads/SS_1-6L.pdf
edited!
PostPosted: February 13, 2019, 2:39 pm
Chuck, that's the same thing I've been seeing. It makes me question these plans from the lumber yard. I wonder in their plans are they using a gable end truss or a Queen truss because it doesn't specify. Queens transfer the loads to the outer walls, but Gables want full bottom chord support.
Of course these plans aren't stamped by a NC licensed PE.
It looks to me like I should order a LVL for the big span and use the 2x12's if I decide to put a single garage door on the West wall.
PostPosted: February 13, 2019, 2:41 pm
Good thing Baby Girl works for Newell Rubbermaid. I have a lifetime supply of Sharpies. Unless the little bastiges keep escaping.
Currently have 4 Sharpies on my desk even the fancy Pro model with a lanyard loop.
PostPosted: February 15, 2019, 10:58 am
Weather forecast says El Nino is about to kick my a$$. Today is clear, then rain every day in the 10 day forecast.
:BH:
I have a conference call then I'm going on a stud cutting spree.
PostPosted: February 16, 2019, 3:10 pm
I would use a plywood box beam or steel for that header. And what are you going to hang your chain hoist track from?
PostPosted: February 16, 2019, 8:36 pm
Too Busy: I am still a PE, but not with a license to practice anymore. But with that qualifier I would do what a plan approver would do here. According to 'Canadian Wood Frame House Construction' the maximum span for Spruce-Pine-Fir Lintels, No 1 or 2 Grade, with structural sheathing, 2 ply 2x12 , is 9ft 10 ins at 20.9psf snow load (the Canuck minimum). Your double door looks bigger than that ....
Warren
PostPosted: February 16, 2019, 9:10 pm
What would the specs be on a steel ibeam that would span, say, 20 feet?
PostPosted: February 16, 2019, 9:29 pm
Hey Warren,
I’ve seen a third 2 x 12 laminated onto the inside of a garage door header for a double size door suported by 2 x 6 door frame that is either set into a 2 x 4 wall (with the extra dimension either sticking out like a brick mold or sticking inside) or into a 2 x 6 end wall. Does that meet the support requirement for a normal 16’ double garage door?
Bill
Bill H
Winnipeg, MB, Canada
PostPosted: February 17, 2019, 11:06 am
BHR,
Too Busy is lucky. The next table in Canadian Wood-Frame House Construction is "Maximum Spans for Built-up Lintels - Roof and Ceiling Load Only - No. 1 or 2 Grade". It provides maximum spans for 3, 4 and 5 ply 2 by beams.
Again for 20.9 psf snow load:
12ft 0in max span for a 3 ply 2 x 10
14 ft 0in max span for a 3 ply 2 x 12 (will carry 31.3psf snow load at 12ft 0in span)
So Too Busy could simply add another 2 x 12 in place of the OSB core. Hopefully the local inspector will have access to similar US-code tables using locally available species.
But sizing an I-beam would require a locally-licensed engineer, although he is likely just to calculate EI for a code-approved wood beam and find a steel I-beam section with equivalent or greater EI.
Edit: A plywood-faced box beam is going to require a stamped drawing. Two-by lumber is probably cheaper. :-)
Warren
PostPosted: February 17, 2019, 12:29 pm
Tommy, is it too late to change the design to two 8ft doors? :mrgreen:
