It is currently September 21, 2020, 10:13 am
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
 Post subject: Car lift install
PostPosted: December 2, 2019, 11:21 pm
So I am getting around to installing my C-7000 car lift and found out that my floor is only 3.5" (actually less that that) where the lift will go which isn't thick enough. So I decided it would be best to pour a new pad. I figured a 5000psi 28" x 28" x 12" deep with a 6" under cut (to tie it back to the existing slab somewhat) would be best. But is it? After looking around online I am seeing everything from 2ft x 2ft to 4ft x 11.5ft requirements will all sorts of thicknesses. Any one have any real thoughts?? I'm not even sure how to calculate the required overturn moments so they I can figure out how much the concrete needs to weigh... I'm not a civil or structural guy. I feel like my size will not be a problem for the race car but at some point I know I'm going to put my Explorer on it and be worried.
Here is the hole :D
 Post subject: Re: Car lift install
PostPosted: December 3, 2019, 2:21 pm
Not a licensed PE, so take this with a grain of salt...
I would make a continuous pad between the two posts, this would take care of the lateral tipping concern, and then make it long enough to go past the center of gravity of anything you would lift to eliminate that concern. I would pour it at least 6" thick with rebar ~2" up from the bottom.
This goes along with what I found online:
Q: How large "stand alone" concrete pad is needed for an
outdoor lift?
A: 2-post lift:
The concrete should be twice the required thickness of a "normal" concrete
floor for the lift's weight capacity. The "slab" should extend at least 24
inches past the outside of each column (side to side) and one foot (front
to back) longer than the end of the extended lift arms when moved to their
"fully extended" position.
PostPosted: December 3, 2019, 7:33 pm
Online
Same here
If I were doing this I would sink a 12"-14"diameter x 6'-8' deep concrete piling (using piling tubes) with rebar and hoist tie bolts for each pillar, kinda like what they do for large street lamp posts.
PostPosted: December 3, 2019, 8:21 pm
Geeze Perry, that seams like a much over built design in my un-Licensed PE opinion. It is ~700# to 1350# of concrete per slab/piling. I was thinking of just driving a few steel rods down a few feet before pouring the concrete. I think 8"-9" dia x 42 inches deep pilings are common for deck supports around here. The depth varies depending on the depth of the frost line. I don't pretend to know myself. Mjalaly, what do the instructions of your lift say is needed? Certainly it is specified somewhere in the installation instructions.
PostPosted: December 3, 2019, 9:32 pm
The instructions are garbage. Even the vendor was no help. They just told me the manual says 4" thickness but that's the thickness requirement for an existing floor... mine isn't 4". I have been reading more on the web and it looks like quite a few people reccomend a 4ft x 4ft pad 12" deep.
PostPosted: December 3, 2019, 10:29 pm
The requirement for Bendpak 10,000 lift is:
https://www.bendpak.com/XPR-10-Series-T ... endPak.pdf
• Concrete specifications. Make sure the concrete is at least 4.25 inches thick, 3,000 PSI, and cured for a minimum of 28 days. Do not install the Lift on cracked or defective concrete. Anchor Bolts must be more than 6 inches from cracks in the concrete or from a wall.
I would trust Bendpak's requirements. They are well respected. Interpreting your situation based on the Bendpak instructions, a min of 6" beyond the bolt pattern of the lift would be appropriate for the cut. 6 inches beyond the base outline would be better with some margin for error. Dig out 4-1/4 inches below the bottom of the existing concrete. Extend the hole under the existing concrete the same 4-1/4 inches on all 4 sides. That would give you the min thickness for the new concrete under the old with a 45 degree angle of "locking" under the old. I would also wash the underside of the old concrete and spray with concrete bonding adhesive to enhance adhesion. not to mention the previously mentioned reinforcement steel. I would check that the crushed stone base under the concrete is still enough since you are digging out deeper than the original excavation and possibly the underfill.
And wait 28 days for the concrete to cure before drilling and installing the anchor bolts.
So the safety factors are:
1) Sackrete and Quikrete found at the home stores are typically 4000 PSI, Higher PSI can be found.
2) You are using a 7000# lift. The above instructions are for a 10,000# lift
3) Cut 6" beyond the base vs 6" from the anchor bolts
4) The Bendpak lifts are ALI certified. I assume that includes the min installation requirements.
YMMV of course and I have no expertise in these matters. But I would not be concerned if I were installing a 7,000# lift using the above guidelines.
Don't come after me if things don't work out for you using these guidelines. :mrgreen:
PostPosted: December 3, 2019, 10:41 pm
Bendpak actually specs out something extreme. Pretty much a gigantic pad with a 6in undercut 12" deep
https://www.bendpak.com/car-lifts/concr ... uirements/
PostPosted: December 4, 2019, 12:59 pm
My Bad! Ignore my earlier posts. :cheers:
It makes sense to me now why Bendpak wants a continuous pour from one post to the other. 2-post lifts do not take a pure vertical load like a 4-post lift does.
PostPosted: December 7, 2019, 7:03 am
IMH and amateur O, for balancing 10,000 lbs on two six foot pillars with a sqft base, I would augment the loading pads with four 1/4x5x5 base plates, ten feet from the upright, bolted to studs epoxied into the floor, then fit threaded rod with a turnbuckle adjustment for tension loads to keep the pillar vertical and help prevent concrete cracking that would require a repour.
Think about an inverted truss (warren,pratt, etc). With trusses, there would be no need for extra thick concrete since the load would be spread over a much larger area. With a long enough truss there would be no need to bolt it down.
Consider what the dynamic load would be if one of the outriggers was not placed properly under a frame rail and a vehicle like a truck with bad weight distribution slipped. Take a look at youtube vids of vehicles falling off lifts.
PostPosted: December 8, 2019, 3:12 pm
So dug some more and now the one side is 28 x 4ft. Just that extra 20in was a lot of work since I don't have a jack hammer. That seam down the center is actually the center of the garage so now I am thinking I should go the whole way and connect the two sides but again that is a ton of work. I probably don't need a 12" depth the whole way maybe just 6 in deep in the center and 12" deep under the pad as shown. I'm also not sure if I really need it to be 4ft wide the whole way. I think 3ft around the lift post is fine. This might work the way it is too since the soil is so damn hard and I would probably pull the anchors out first.
PostPosted: December 10, 2019, 12:58 pm
I think Home Depot rents electric jack hammers. That might help you a lot.
PostPosted: December 14, 2019, 11:45 am
Maybe dig down and add a sonotube.
File comment: Sonotube
Dan Lipperini Jr
www.RaceLabz.com
PostPosted: December 15, 2019, 7:54 pm
Closer. I just need to dig some dirt and then have someone cement dirt in.
Do I need gravel at the bottom or just mesh?
PostPosted: December 15, 2019, 9:32 pm
You need;
- a well compacted base...don't skimp on compacting the base (!!!), and
- mesh or other reinforcing steel set up on chairs so that it will remain in the center of the new pour plus you'll need to vibrate the pour to eliminate voids under the steel, and
- reinforcing steel bars that are epoxied into holes drilled in the side of the old slab all around the perimeter of the hole to tie the old slab and the new slab together.
Check your local building code for specs on the steel size required, the spacing of the tie bars and the spec of the epoxy.
Have fun! (I'm not a fan of concrete work)
Bill H
Winnipeg, MB, Canada
PostPosted: December 16, 2019, 9:19 am
Typically, the stronger reinforcement comes from rebar tied together and embedded about halfway down into the concrete. If you Google "rebar", you will see samples showing sizes and ways to tie it together. Typically, you just need to runs some lengths across the long ways of the opening and a few across the lengthwise lengths. You can tie them together with some steel wire twisted around each crossing of the rebar.
File comment: Rebar in pattern
The other choice (also a little bit easier) but not quite as strong, is use wire mesh.
File comment: Wire mesh in concrete
Make sure you use something to support the mesh or rebar off of the ground to allow the steel to embed into the middle of the concrete pad. And do add gravel at the bottom of the new opening, this allows you to be on a solid bed. This gives resistance against "bending" and transfers the pressure to the entire slab.
Thom
