It is currently May 17, 2024, 11:14 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Smiths MGB GT Build
PostPosted: July 5, 2022, 1:30 am
Way back when I had hair, I was working as a auto mech at a service station. Fall time was rad flush season. We had a machine that used water and air to flush a cooling system. I hated the Ford engines, you pre-tested the antifreeze before you did the flush, you couldn't read the gauge because the coolant looked like black coffee. You did a 20 minute flush, installed brand new antifreeze/water solution, tested the antifreeze and couldn't read the gauge because it was black like coffee.......explain that to the customer :BH:
PostPosted: July 5, 2022, 4:05 pm
I had hair once. I can't even grow out my bangs now.
I flushed it out today. Still green (thankfully no black coolant though the evapo rust stuff tends to make it so) but the rust was gone completely. During the flush, I saw a little brown when going through the htr core but otherwise a win for a 1/4 cup of metal prep. A gallon is about $15. If my radiator pops or pump leaks in the next few months, I'll post about it. :cheers:
PostPosted: July 8, 2022, 2:12 pm
Awesome to hear. I'll try to flush mine in about a week from now. That will put about a month with several hours of use on it. The cars temp guage needle still gets uncomfortably close to the H mark in this hot weather. Hopefully with some real coolant, it will bring it down a bit.
PostPosted: July 8, 2022, 5:24 pm
Heat transfer is better with no antifreeze but a terrible idea without rust preventatives.
I'm sure there are a few things you could do to improve the cooling ability. Consider that your lower core tubes are probably clogged from sediment and flushing through the hose fittings does not force water through all the rows of tubes. You may need to have the copper brass radiator taken apart by removing the solder on the tanks, dipped to clean, then wire is pushed through each tube to ensure it is clear before resoldering. A few shops like that still exist but it may be a lot cheaper to replace it with a new aluminum radiator that will cool better than the original cleaned.
It is common for the old radiators to have pin holes after cleaning (acid dip) and require a new core between the old tanks. All that stuff is less common and much more expensive now.
I'd put a cheap, modern replacement in and put away the original in storage for the next owner.
A better than original engine driven fan with flexible stainless blades or fan clutch may be available for less noise and more power.
EDIT: I see there are a couple different style hose fittings available. Here is one: https://www.ebay.com/itm/125405443312?h ... R7aD5qW8YA
Here is one guys experience where he adapted a different style than what he had:
https://www.mgexp.com/journal/Charles-D ... get.18407/
PostPosted: July 14, 2022, 10:20 pm
Heres one month and maybe 6ish hours of run time on the second flush of Thermocure.
The good:
It looks like non-oxidized metal in the jackets now and much of the mineral deposits are breaking down. I do believe you can restore your system to "like new" if given enough time.
The bad:
The car will over heat even after just a few miles.
I'm no chemist but some sort of molecular magic has happened. What was a black liquid has become a milky (not oil contaminated) substance. Maybe the lime is breaking up but there was very surprising amount of it. There was also a bunch of stuff like ground up chalk mixed into a paste covering almost the whole system (possibly more lime).
After a few hours (yes, hours) of flushing the system every which way I could, I finally managed to get clear water through it and looking through the thermostat hole, the jackets looked fairly clean. In that time I would take it for a short drive to heat everything up and get all the crud suspended and now the radiator must be mostly plugged up because it'll get too hot after only a few miles. The radiator allows water from the garden hose to pass through without and restriction but there must be some obstruction. I've flushed it each way a number of times but still the same result.
I replaced the thermostat just in case and am going to do another flush but with only short loops around town to prevent overheating.
Thanks for the like, Miatav8,MstrASE,A&P,F for the link. Once I get the block super clean, I believe I will go to an upgraded aluminum radiator and a better fan.
PostPosted: July 14, 2022, 10:28 pm
Pics:
PostPosted: July 14, 2022, 10:48 pm
Does this car have a thermostatic fan?
PostPosted: July 15, 2022, 12:01 am
I would call that a success! Well done.
PostPosted: July 15, 2022, 12:17 pm
It has a fixed blade fan. The factory original I believe.
PostPosted: July 15, 2022, 4:42 pm
Ok cool, sometimes a thermostatic clutch fan will fail to lock up when hot causing over heat problems.
PostPosted: July 16, 2022, 11:16 am
I will say that the fan isn't very effective. I may swap out for a plastic fan but I'm really looking towards going with an electric fan or duel electric fans with a shroud.
PostPosted: July 16, 2022, 4:30 pm
It looks like there isn't enough room to fit a flex fan and a spacer/adapter fan pilot to clear the mgb pump pilot and for the flex blades to clear the belt.
I suggest using the best bolt-on engine driven fan with shroud and as a back up, install a 12 inch (advertised size) hayden pn 3812 as a pusher, with the long dimension lateral so it only overlaps the tanks by an inch or so. The fan(s) you select to push should pull at least 15 amps (combined if two). The core height of less than 10 inches makes it tough to find a fan with enough output. I suppose you could run two 8 inch fans if you can find them. Beware of all the junk fans on ebay.
PostPosted: July 17, 2022, 8:29 am
You have a 68 which should be the first year for the metal six blade fan. It looks like the pump hub and pulley are different but worth the change. I wouldn't use the plastic seven blade fan which is fragile.
I'd restore an original fan and large pilot pulley like these:
https://www.ebay.com/itm/264701395835?chn=ps
https://www.ebay.com/itm/154966061411?h ... R8Th1L_BYA
This would be a good pusher add-on (Hayden "12 inch", #3911, 12.8 amp):
https://www.ebay.com/itm/165564076246?e ... R_aXrsHBYA
Derale stand alone- no engine driven, puller if you have room or pusher (thick fan):
https://www.ebay.com/itm/115152757528?_ ... =193147584
PostPosted: July 18, 2022, 1:42 pm
Thanks for the suggestions.
I have this radiator ordered now.
https://www.ebay.com/itm/163705370168?m ... media=COPY
I found two sizes of the hayden electric fans at the auto parts store for a reason price.
I checked the fan fitted to the car and I see that its the same as the one in the link but yellow.
Also ordered a thermostat blanking sleeve to run without the thermostat.I have been reading about how they can be used together with a thermostat to keep temps down by preventing coolant from bypassing the radiator.
https://mossmotors.com/sleeve-thermo-bypass-blanking
PostPosted: July 23, 2022, 6:45 am
I think the blanking with a stat is a great idea. Tough to restrict the bypass on that engine.
