Perry's 5th build, the Super Slant 6 Super 7
Tell us about your project and keep us up to date.
horchoha
Building: locost super seven
Re: Perry's 5th build, the Super Slant 6 Super 7
Post by horchoha »
tibimakai wrote: November 12, 2025, 12:06 pm Even I'm considering that style of hinge/hood setup. Still thinking about it to do it, or not.
What you have riveted to the nose cone? Left and right from the yellow tape.
Hi Tibor
The nose is riveted to a 16G metal frame to keep it rigid and provide mounting points. Where the nose frame meets the car frame (cleo on each side) I used 1/4" bolts to mount. Then where the hinge support meets the nose frame top center there are also 1/4" bolts. This makes the nose very rigid once mounted.
JAMADOR
Building: FC RX7 Based
Post by JAMADOR »
My father-in-law's Indian Scout is a similar orange. It was the color I was planning my 7 before it had to move on to the next owner.
tibimakai
Building: 442E
Post by tibimakai »
The nose is not fiberglass? Mine it is, from Kinetic, and it is super strong, I don't need a frame for it. Just used two Dzus fasteners up there and two at the bottom.
If I will fail to make a one piece hood that it will fit nicely, I will resort to this type. It is way cooler, then the one piece. Also, every time you would remove the one piece, always have to think where to place it, it can be damaged easily. It is easier to make two small pieces, than one big piece.
Tibor
'20 Alfa Romeo Stelvio daily
Locost/442E in progress
horchoha
Post by horchoha »
tibimakai wrote: November 13, 2025, 12:45 pm The nose is not fiberglass? Mine it is, from Kinetic, and it is super strong, I don't need a frame for it. Just used two Dzus fasteners up there and two at the bottom.
The nose is fibreglass and yes it is strong. I just built a steel frame for it because of the build style of the hinged hood. I've done it this way on my three previous builds.
horchoha
Post by horchoha »
Hood halves are rough cut. Decided to polish them prior to forming and final trim and fitment.
horchoha
Post by horchoha »
So I finished polishing the DS hood panel and started thinking how do I form and trim this panel without marring the panel. Then I thought to myself "Self, I know what I can do!"
I went to the store and got me some self adhesive cupboard shelf liner. Put it on the panel and now I can handle the panel with no worries.
B85
Post by B85 »
You have her looking great ! Well done.
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Post by B85 »
Perry, this made me think of you.
https://www.youtube.com/watch?v=I7daGYuiD6U
American 7 5.0 T5
Lotus 15 ish?
914/H6
horchoha
Post by horchoha »
lol, thanks for the link B85
325 ponies with 400 lbs torque is insane
BUT there are 2 take aways from that video
(1) I wish I had a shop that clean I could eat off the floor
(2) I wish I had that kinda coin, lol
(3) I wouldn't be able to keep my 7 between the lines with that turbo'd, ported and polished, blueprinted jewel of an engine
(4) But it's nice to dream.......
And that's the 2 take aways in a nut shell :cheers:
horchoha
Post by horchoha »
Well I don't have a vertical post in the centre of my shop like the old coach builders did but I do have a 4" plastic tube mounted on a couple of saw horses. Using this to massage the DS hood panel.
Slow work, took me around 2 1/2 hours to get this result and I'm not finished but it is progress.
horchoha
Post by horchoha »
Measured the rivet spacing at 2". Lightly centre punched and the drilled 1/16" pilot holes. Set hood half in place, positioned, and drilled and cleo'd.
Some pics.
tibimakai
Building: 442E
Post by tibimakai »
Very nice!
You will have some foam tape on the chassis?
I was wondering how that would look like to have a tape under the bonnet, but not under the scuttle. Wouldn't look weird?
Tibor
Miatav8,MstrASE,A&P,F
Post by Miatav8,MstrASE,A&P,F »
Looks great as usual... :cheers:
B85
Post by B85 »
:shock:
American 7 5.0 T5
Lotus 15 ish?
914/H6
Users browsing this forum: Semrush [Bot] and 10 guests
