It is currently Sat May 18, 2013 5:37 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: 3.4 DOHC V6 Turbo McSorley +4
PostPosted: Thu Sep 08, 2005 8:07 am
Hiya
Thought my first post should be a run down of my project.
Its a big mix of small GM parts, S10, wbody, etc.
HX40-w
Turbo Grand Prix Intercooler
Couldn't find any V6 collectors, so my buddy just made some
there's still alot more structure and suspension stuff to do, hopefully all that stuff will be done by spring.
PostPosted: Thu Sep 08, 2005 8:45 am
That exhaust work looks great! It looks like you're planning to run the exhaust down the tunnel?? Or are you going to kick it out to the sides just behind the 3-into-1?
Also it looks like you've got a shift extension bolted to the trans. What kind of trans is that and is the shifter re-located?
PostPosted: Thu Sep 08, 2005 9:14 am
the headers need to be shortened a bit still, they're going to kick up right infront of the firewall to feed into the turbo that will sit ontop of the trans.
The trans is a T5, and yeah, thats the first attempt at the shifter extension, I think its still going to need some tweaking, but it works pretty good so far, really short ratio gear shifts.
PostPosted: Thu Sep 08, 2005 10:21 am
Looks great!
Is that a S10 tranny? On the fbody one the shifter location is further back ...
PostPosted: Thu Sep 08, 2005 10:43 am
thanks! :)
yep, the T5 is from an S10 4 Cylinder that came with the dual starter bulges to accept the FWD starter orientation
PostPosted: Thu Sep 08, 2005 12:04 pm
That thing is going to be a beast! :shock: Great work!
PostPosted: Thu Sep 08, 2005 12:50 pm
Yes that exaust look beautiful.
I think you would be better though if you made the headers shorter, more straight back. With the turbo you really want to keep the headers as short as possible, this will prevent lag when the exaust has a chance to pressurize. It really shouldnt be too much of a problem unless you plan to race it.
PostPosted: Thu Sep 08, 2005 12:54 pm
I didn't want to do a Log style manifold, the engine is going to spend most of its life in the upper RPM's so flow was more important to me. Plus, it just looks cooler this way, heh heh. The overall performance of them isn't that important as long as they'll be able to flow good enough to be able to spool up the huge turbo I have. The car should be somewhere in the 300-400hp range, at a weight of 1500lbs or so, that should be plenty for now I think.
PostPosted: Thu Sep 08, 2005 12:56 pm
I sent you a PM
PostPosted: Fri Sep 09, 2005 3:49 am
MAN! Those A -arms are sexy.
THe Headers are a NICE bit of work too!
How much do you figure your A-Arms cost?
What size tubeing are you useing?
And spindle sticking out of the A-Arms, What type are they?
Very Nice so far....
I'll keep an eye out for you!
To err is human...
I am more human than most.
PostPosted: Fri Sep 09, 2005 6:35 am
How much do the A arms cost? I couldn't say, took a while to make the lowers. The tubing is 1" thick wall, they use it on circle track cars and stuff I think, so I thought it should be good enough.
My lower ball joint? thats just stock S10 xtreme bits to match the spindles.
PostPosted: Wed Oct 26, 2005 3:14 pm
ahhh, nothing done on my car still..... I decided to fiddle with the rendering of my car to help ease the pain...
Changed the color, i'm feeling a deep champagne red now, with ox blood interior.
PostPosted: Sun Nov 20, 2005 11:01 am
uh oh, screwed this one up some how.... I'm making a custom intake plenum to fit my corvette throttle body, but somehow the measurements from the file transfer got screwed up big time, the holes were all the right size, but the spacing was all fucked up for some reason....
so, next week, I'll have to try and figure out how the laser cutter got confused...
PostPosted: Tue Dec 06, 2005 1:20 am
Since I'm now contemplating a similar path, I must ask what type of engine that is and what's it out of. Is it a 3800? Is there a way to use this drivetrain without a shifter extension? I guess what I'm asking is did you move the motor and tranny any further forward to make room for the turbo bits or is that just where it best fits?
PostPosted: Tue Dec 06, 2005 2:20 am
its a 3.4L DOHC out a Chevy Z34 - made piles of power - rumoured to have been detuned so the (fwd) tranny could survive.
