It is currently Sat May 25, 2013 3:14 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Sealant that holds up to gas & oil?
PostPosted: Thu Jul 29, 2010 12:16 pm
I had to pull my intake manifold off yesterday because the vacuum chamber underneath developed a vacuum leak. Caused havoc with my efi! it has a chamber cast into the manifold that has an aluminum plate cover, held down by bolts. I used motorcycle case sealer on to seal the mating surfaces, it became brittle and now leaks. Does anyone know of a pliable sealer that can handle exposure to gas and oil?
Rod
and a 1963 Nova SS
 Post subject: Re: Sealant that holds up to gas & oil?
PostPosted: Thu Jul 29, 2010 2:39 pm
hi best all around sealer i have ever used , permatex great stuff.
seem to work for things they never intended too.
PostPosted: Thu Jul 29, 2010 3:22 pm
spindlefied
If that's the orange stuff, I have to agree. Sealed a hole in my front diff with that stuff and it lasted for years.
-Michel de Montaigne
PostPosted: Thu Jul 29, 2010 5:00 pm
Except it says not to use when in contact with gasoline. I don't want to find out the hard way that it won't hold up!
Rod
and a 1963 Nova SS
PostPosted: Thu Jul 29, 2010 5:38 pm
Maybe give the folks who made the manifold a call?
PostPosted: Thu Jul 29, 2010 5:43 pm
http://www.gasgacinch.com/index.htm
put the good stuff in the good stuff. .. wrong product for that tagline but you get the idea.
PostPosted: Thu Jul 29, 2010 5:54 pm
Gasgacinch, I have a big fat can on my bench! Never thought of using it for this......Thanks
The manifold maker won't take questions or respond to my calls! I bought the manifold on ebay.
Rod
and a 1963 Nova SS
PostPosted: Thu Jul 29, 2010 6:21 pm
http://www.aircraftspruce.com/catalog/a ... ealant.php
if you don't mind spending $$ or if you know someone in the aviation field that could help you out.
Austen
upstate NY
airframe mech
09 109R
04 IS300
91 MR2t
93 toyota PU
91 alltrac (gt-4)
PostPosted: Thu Jul 29, 2010 10:08 pm
hi that gasket will not be in contact with gasoline, greatstuff will work fine.. it is black, comes with a small caulking gun.
PostPosted: Thu Jul 29, 2010 11:28 pm
It WILL be in contact with gasoline, hopefully not much but gas will get in there.
Rod
and a 1963 Nova SS
PostPosted: Fri Jul 30, 2010 1:35 am
Threebond Silicone Liquid Gasket should be available at finer motorcycle shops everywhere. Used it for sealing motorcycle and jetski cases for years never had a leak.
___________
Yep I got a build:
PostPosted: Fri Jul 30, 2010 2:25 am
Rod
Why would it be in contact with the fuel?
Your ITBs go directly into the heads, do they not? Injectors are pointed down the intake, correct? They might get a hint of vapor, but if it's truly under vacuum it would be cleared out on the next available intake cycle.. and you have 2x as many of those as most of us do!
I would worry about fire and explosions if your getting puddles of fuel in a vacuum chamber. There shouldn't be any thing but... well, vacuum in that chamber!
Maybe I'm missing something in it's design, but it seems odd to have unburned fuel around in the manifold. And I have to +1 for the PermaTex... AWESOME stuff!!
KS
FYI - Gasgacinch is only gasoline resistant too.
Don't ever become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Robert A. Heinlein
Add yourself to the Locost Builders Map!
Jigsaws, Hacksaws... There is a better way! Want to get creative with metal? Want a Plasma Cutter but can't justify spending the $? Check out a DIY Plasma Cutter! A true LOCOST way!
PostPosted: Fri Jul 30, 2010 2:46 am
I understand what you are saying, but gasoline vapor is still gasoline. Plus it will probably get a little in there at every start up and possibly at shut down. I just don't want to take a chance. Its PITA to take the manifold off with the EFI setup plus, I need reliability for going on long trips. Don't want to take it off again for a long time!
I need to read the data sheet on the stuff from Aircraft Spruce, it sounds like the best thing so far. I don't really trust Gasgacinch over the long term either for this, but I use for many other things.
Rod
and a 1963 Nova SS
PostPosted: Fri Jul 30, 2010 6:30 am
I'll check at work and let you know what is available from Permatex that is gasoline stable.
PostPosted: Fri Jul 30, 2010 7:21 am
Permatex 300, Don't leave home without. Even brake fluid will not touch this stuff.
Dave W
