It is currently Wed May 22, 2013 6:23 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Limited-Slip Differential - How important is it?
PostPosted: Sun Aug 01, 2010 3:18 pm
Hey gang, So, my Miata donor has provided nearly everything I'll need for running gear. However, one thing it doesn't have is an LSD.
How important is a limited slip diff?
-What will I be missing out on if I stay with the open differential I have?
-Is having an open differential desirable at all?
-Does a Seven even work at all with an open diff?
If it is critical to get an LSD, which do I get?
-Do I source a Miata LSD?
-Do I need to find a Torsen differential, or is a viscous LSD satisfactory?
-Are there betterl lighter, stronger LSDs than the Miata I should consider sourcing before starting the build?
Thanks for the enlightenment!
 Post subject: Re: Limited-Slip Differential - How important is it?
PostPosted: Sun Aug 01, 2010 3:32 pm
How important is a limited slip diff?depends on your use
-What will I be missing out on if I stay with the open differential I have?again, depends on your use
-Is having an open differential desirable at all?not really but for inital shakedowns you won't mind at all.
-Does a Seven even work at all with an open diff?yes, remember the miata had an open too
If it is critical to get an LSD, which do I get?personally i recommend a torsen type unit
-Do I source a Miata LSD?sure why not?
-Do I need to find a Torsen differential, or is a viscous LSD satisfactory?again, depends on use, i use a viscous when building for smooth transitions and calm driving styles but prefer the torsen type for performance vehicles
-Are there better, lighter, stronger LSDs than the Miata I should consider sourcing before starting the build?you can always make small changes mid build, driveshaft and axle attachments to the diff are just as if not more important than a lot of other considerations. "better" is subjective in a lot of things. ..
PostPosted: Sun Aug 01, 2010 6:53 pm
Limited slip
Good for high horsepower situations,
Good for driving away on ice or wet roads in a straight line
Good for going crosswise and throwing your car in a ditch on icy or wet roads
Good for putting your car sideways in a curve under power and doing a 360
Good for breaking an axle when it locks from side to side, assuming your axle is weak and your engine is strong
Great entertainment for your friends assuming you have enough power to fishtail
Open diff
Good for burning one tire off while in a curve
Good for a smoke show to impress your friends
Good for hauiling butt around a curve assuming your tire has traction
A little tongue in cheek, but to be honest these are fun cars and a LSD is strictly up to you, even the early Shelby Mustangs didn't come with an lsd as standard equipment, each has its limitiations, though in the end an open diff is safer to drive in most conditions.
Personally I would think the average Miata doesn't have the power to really warrant it unless you are really serious about racing it.
In my build I happen to have a limited slip, not because I went looking for one, but because the cheapo rear end I found happened to have one.
I would say run it as is, if the need arises later then look for one. You would also probably get a better price if you are not in a hurry in your search.
Al
1969 Amx
2004 Passat 1.8T 5Spd 4Motion
Super Seven 3.4 snooze build
Build Log viewtopic.php?f=35&t=2391
PostPosted: Mon Aug 02, 2010 12:32 am
If you drive normally you don't need one. If you push a car then it's better to have one.
The most noticeable missing thing will be the two wheel burnouts you can do if you have LSD. Really though, most of the advantages of a LSD are subtle. The one vs two wheel burnout is the most noticeable so it is always mentioned.
If you've ever driven a racing one wheel drive go kart on a road course you just could not take left and right corners at the same speed. When you put a solid axle on the kart then the way you took corners changed (assuming you had enough power). You went from "ol' smokey one tire" to outlaw sprint car sliding style if you wanted to. :mrgreen:
As an example,
The only thing I can think of is if you drive like an old lady then you will save some weight by not having the LSD components in the axle.
This is a trick question right? :)
-Are there better lighter, stronger LSDs than the Miata I should consider sourcing before starting the build?
If you aren't going to be die hard racing I'd just use whatever LSD you find. You can always change to a different type once you have the car on the road.
Some of the comments about LSD causing problems in the rain have me perplexed. As an example, I purposely floored my XKE in low gear when going around a 90° street corner as I went through a water puddle to see what it's LSD would do. The result was very uneventful other than the car taking off around the corner very fast with neither tire spinning. With LSD you have -more- control because both tires are getting power.
PostPosted: Mon Aug 02, 2010 10:26 am
Some limited slips have more bias than others. For instance, a Detroit Locker can be a real bitch in the rain and painfully noisy when backing up or in tight corners as the dogs engage/disengage. I prefer clutch style (positraction, Auburn, Trac-loc) diffs in a street car.
One thing you do not want is a spool!
Jack Collins
PostPosted: Mon Aug 02, 2010 11:13 am
olrowdy with limited slip on any slippery surface it can get hairy due to the fact that both tires let loose suddenly. When you don't have an LSD one tire stays planted.
I realize a kart is a different beast but the solid rear axle is the ultimate in locker, but in many cars the LSD causes push so how does that kart handle that? Anyone gone from the one wheel drive to solid axle and can tell us?
A friend of mine put the LSD in an Elise, against Lotus' advise, and became just enough slower to keep him out of the points hunt. He went back to the open diff and jumped right back into the fray at or near the top.
PostPosted: Mon Aug 02, 2010 11:28 am
What's your budget and what are your goals? Is your Miata a 1.6L or 1.8 L open diff?
If your goals are Low- Cost over outright performance, you can always build the car with the stock open diff and upgrade to a Miata LSD as desired at a later date. If yours is a 1.6L donor you can upgrade to a viscous rather cheaply, as the smaller 1.6L diffs in general are not very highly regarded in the heavier Miata world. This would certainly be the Low-Cost option to get improved performance, and should still be plenty durable in a lightweight Locost application. For the 'ultimate' setup, going to the Torsen diff out of a 1.8L Miata is also very feasible. Miata people have been doing this for years, although it will cost a bit more money as you will need to source the more desirable/expensive differential unit, as well as the matching axles and driveshaft. If it's already a 1.8L open diff car there probably isn't much to be saved in buying the parts to convert to a 1.6L viscous diff, so just go with a factory torsen or add one of the available aftermarket LSD. Overall there really aren't many reasons to go with any heavier duty of a differential than the Miata 1.8L Torsen when using any Miata drivetrain and running gear.
PostPosted: Mon Aug 02, 2010 11:58 am
the torsen weights more than the Mazda comp clutch type
William Keeling
Houston Texas
Spec Miata Racer
PostPosted: Mon Aug 02, 2010 12:28 pm
Don't assume there'll always be an LSD available of you change your mind later. For some axles there simply aren't any, so check first!
Regarding rain, an LSD can make a huge difference, depending on type and power level. Because it's a limited-slip, that means that on a tight turn, the inside tire is being forced (to some degree) to spin faster than it wants, which happens fairly easily in wet conditions. That means the car's already lost traction due to the inside tire having lost its grip, and we haven't even considered lateral load tranfer. I've had several cars with clutch-type LSDs and they were a real handful in the wet.
PostPosted: Mon Aug 02, 2010 1:32 pm
When I first got my Locost on the road (2006), it had an open diff. I used a Corolla GT-S axle (the LSD was not available in Canadian Corollas). While I drove it a lot to work, I autocrossed the car regularly as well. I fought oversteer which I tried to tame with front sway bar and chassis rake, but it just wasn't quite "right."
In 2007 I found, rebuilt and installed a factory OEM Corolla GT-S clutch-type limited slip.
The addition of the LSD transformed the car, to the point that I would highly recommend an LSD even if you never race it. It is much more composed on the street, and much more controllable in autocross.
There is a bit of chatter on tight turns if the road is dirty at all.
The OEM LSD is pretty tame, and I think it's perfect for the weight of the car. I figure if I pop the diff (they aren't that strong), then I would find a used TRD unit. I would avoid the KAAZ or CUSCO because in a car this light, the car would likely go straight or sideways and not be as much fun. OBX has (had?) a torsen style lsd that I might try at some point, if it doesn't burst into flames from sheer low build quality.
For a 7, I would recommend a torsen style diff, or a soft clutch type. Avoid the locker style unless you like drifting.
The Lethal Locost
PostPosted: Mon Aug 02, 2010 3:09 pm
I have autocrossed a 1999 Miata with an open diff and then with the torsen installed.
The torsen made a huge difference. I'm building my car with the torsen without question.
PostPosted: Mon Aug 02, 2010 5:26 pm
Yep, one tire planted but with a sudden reduction in power applied to the planted tire. Not a good idea if you are in a high speed turn. So you let up on the gas to stop the spinning tire and now both tires grab with reduced or no power when they were sliding to start with. But you are still in the middle of a high speed turn coming off the power! Now you are really in deep do-do.
We may be talking about different scenarios here. I'm thinking more of high speed open road conditions. You guys may be thinking of flying around tight corners in town (in the rain/snow/ice yet). Also I am thinking along the lines of driving a high performance car under controlled conditions (which most of us are doing here) and not freaky conditions that LSD or not you don't have a lot of control over.
Open road;
I truthfully don't remember many situations where rear tire(s) break loose "suddenly" (as in "unexpectedly") with or without LSD. But I'd rather have both tires break loose than one tire go up in smoke with the outside tire loosing power when you need it in a turn. I did have two monstrous hydroplaning "incidents" which were unexpected and you have very little control over anything.
I grew up driving fast with a souped up '40 Ford coupe (no LSD but I did have a Columbia two speed rear axle) and I never noticed one tire breaking loose when taking open road corners at way too high speeds. In affect the car was already in a (hopefully) controlled four wheel drift.
I've mentioned this in another thread, but with my Ford if I went around the same corner at increasing speeds you will reach a point where the car really couldn't be driven any faster around the corner. Say 50 MPH is the top speed by just driving around.
BUT
If your car is set up for it you can go around the same turn at maybe 70 MPH or more (depending upon the turn) by tossing the car into a 4 wheel drift. Even with no LSD you don't have one tire spinning wildly. (Try -that- on nylon recaps!!)
Yep, I did. IF you have enough power and both rear tires are spinning the "push" affect isn't that bad since the front tires were also sliding in a turn. You do have to compensate for the four wheel drift. With one wheel drive you just had to slow down in right hand turns because you were going wear out your inside tire if you didn't.
I found the kart a more violent version of my Ford slides since I was pushing the kart to the limit to see what it could do. Kinda hairy to sometimes approach a turn under full power when others had braked and then sliding past them at a ~45° angle -before- entering the turn!
I saw Paddy Hopkirk(?) do the same thing at Sebring one year with a Mini (or similar car). Luckily I had read how he took corners while rallying in a sports car magazine so I was intensely interested in actually seeing him do it. Amazing control.
On my website I have an article about "Driving a BEC." and I mentioned bad push when taking off around a corner in low gear under too much power. But it was probably a combination of the LSD and weight transfer. I'm quite sure my car would do the same thing without the LSD since the back end goes down ~5" under a Banzai charge (and the front end comes up another ~2" when you get to 7,000 RPM). BUT the important thing to notice is that one of my rear tires doesn't spin in turns!
Here's a Busa powered kart doing some fast corners. Being attuned to what the kart is going to do there is no sudden break away, just raw power in action.
http://www.youtube.com/watch?v=zWT6xd3qvkg&feature=fvw
OK, but what rear end were the faster guys running?
PostPosted: Mon Aug 02, 2010 6:12 pm
Wet street aside. I feel that an LSD is a requirement for any serious sports car. What's the point of building something and just spinning the inside tire in a turn. Adding an LSD to my cars has been (next to tires) the single biggest improvement in performance. The more twisty the course the more it helps. On the other hand, if you're just building a street car, don't bother.
PostPosted: Mon Aug 02, 2010 10:22 pm
Explain the fact that the Lotus Elise gets slower with the addition of a LSD then? That's a serious sports car and it does better without one, even the Lotus engineers agree. :)
And Ol'rowdy I have no idea what you are talking about in your anti open diff scenario above. Carguy makes excellent points about why an open diff is safer for the average driver. You might want to better explain that "situation" you describe where you loose forward mo and both tires break loose because of the open diff. I've never heard of or experienced anything like that. IMHO The more likely scenario with an LSD is that you are mid turn and momentarily break traction with the rear from a wet spot, gravel, poor throttle modulation or what not and BAM!- you're now sideways. With an open diff, only one tire breaks loose, usually the inside one (in a turn) which leaves the outside tire with no forces to deal with other than control of lateral roadholding. (which increases cornering stability) I've driven and abused vehicles of both types and I've never experienced what you describe. The open diff to me acts like a "governor" that doesn't let you put enough power down to step the rear out unless you are already at the limit of traction, in which case a LSD would've had you sideways long ago.
What I have found in a nutshell is that a LSD will cause a bit more understeer on track, (hurts on corner entry and helps on corner exit) will make it more likely for you to spin your car out and loose control when you don't want to, and will enable you to spin it out in a semi controlled manner and drift it when you do. Not to mention it helps on slick roads and what not, but who drives their 7s in these conditions anyway. (besides Jack and G :P ) An open diff really isn't a curse and a LSD isn't a necessity. My advice is build it with what you got and if you get adventurous later then go ahead and install an LSD.
PostPosted: Tue Aug 03, 2010 12:41 am
Explain the fact to Elise owners found that they do indeed need one for autocross events, where load-transfer is high. For more straight-ahead driving, it's not needed as much - it's all by degree. :)
