Summary of engine weights
Potential donor discussions and troubleshooting, gas, diesel, electric powered builds etc..
Yeroon
Building: Mazda B2600i
Re: Summary of engine weights
Post by Yeroon »
Also got a weight for a 20r (it was on wheels and the 22r's werent, so maybe I'll get a 22r weight another day)
290lbs with full flywheel/clutch assembly, distributor, and alternator. Some oil and coolant as well (basically pulled status)
Heres what was left on the front of the engine:
and the back:
I know it doesn't look it, but it is off the wheel dolly. I was lifting with a ratchet strap, and they dont do controlled release very well, so I wasn't about to raise the engine super high.
We race the 22r in a dirt oval truck, don't believe the internet that these things explode past 5500. We run 4500-6500rpm, with 4 years and counting on the first stock rebuilt engine. (Later style with single row timing chain)
Braindead
Building: Locost style vehicle
Post by Braindead »
I hope I am allowed to post this, it took a long time to find a list that I have at least some small amount of belief in it's content and weights. https://forums.24hoursoflemons.com/view ... p?id=12009
Locost_Johnh
Building: Locost +4
Post by Locost_Johnh »
Unfortunately that list is decades old and the weights don't come close in a lot of places. I tried contacting the original author about 15-20 years ago to give him some accurate information and could never find a working email. Since then many many copies, some modified, have sprung up on the web. You can't trust it.
TRX
Building: Locost variant
Post by TRX »
Locost_Johnh wrote:I tried contacting the original author about 15-20 years ago to give him some accurate information and could never find a working email.
You can find him here:
viewtopic.php?f=4&t=4299&start=120#p145620
That Angelfire address has been dead for a long time; maybe ten years before the date on that list. The earliest versions predate the Web. Perhaps someone tried merging two or more versions.
I quit updating the list because, of all the things I've ever done on the internet, that list has caused me the most grief. I used to get bombed with *angry* rantings from people who didn't agree with it, and felt it was somehow my fault, instead of directing their spleen to any of the original sources I referenced.
Between that, and seeing edited versions "copyrighted" by other people, and the general hate the list seems to engender in a certain type of person, I quit uploading new versions.
STranger 7
Building: 442e with ranger V6
Post by STranger 7 »
In my defense the moon was full and I was left unsupervised
KB58
Building: Midlana
Contact:
Post by KB58 »
In general, modern aluminum 4-cylinder engines are about 300 lbs, and the transmission/transaxles around 80-90 lbs, so figure about 400 lbs for the entire lump.
Carnut99
Post by Carnut99 »
oddsaabs wrote:Just cross posted from another thread about bike engine weights:
Kawasaki ZX14 weighs 220#, puts out 187hp and 113 lb-ft torque in a package that measures about 17" long, 20" wide, and a very tall 25" from the very bottom of the stock oil pan to the top of the throttle bodies. Aftermarket pans with baffles can reduce that height by 4"
Hope that helps.
Heavier than a Hayabusa but I do wonder how they stack up against each other. Only seen a few bring up the zx14 when it comes to engine swaps.
Laminar
Building: Hopes and Dreams
Post by Laminar »
Hung another engine from my scale.
2012 Mustang 3.7L V6. Includes: Intake manifold and throttle body, shorty headers, wiring harness. Missing: alternator, starter, flywheel/clutch/pressure plate.
Total: 360lbs.
The MT-82 including the remote shifter that bolts up to it (or any EcoBoost V6): 128lbs
Once I add a lightweight flywheel, pp, clutch, starter, and alternator, I anticipate the combo being in the neighborhood of 550lbs. That's bang on the same as my 302/T5. A stock block 347 stroker seems like a bargain for power-to-weight, though you'd need to drastically upgrade the T5 to hold the power reliably.
Ford 5.0 into an M3
Lonnie-S
Building: V6 Powered Locost
Post by Lonnie-S »
@Laminar
Good choice on the 3.7 Mustang. It wasn't available when I started my build, so I used the previous generation 3.8L OHV V6. I'd have much preferred the 3.7L had it been available. However, my 3.8L dry, but all-up including the T5, is 506lb see it BOP here, so a pretty good combination.
The biggest issues for me were it's very deep oil pan, and the large bellhousing, which is essentially the V8 bellhousing.
JAMADOR
Building: FC RX7 Based
Post by JAMADOR »
I'll have to try to get mine on a scale.
I know the 13B is a heavy lump, somewhere in the 225lb range.
Trans is pretty light, I had no problem carrying it by hand across the garage. I'd guess <100lbs.
Laminar
Post by Laminar »
Lonnie-S wrote:@Laminar
The T5 is only 75lbs which is great, compared to the 125 for an MT-82 or the 135 for the T56 Magnum. Getting that sixth gear and a stronger transmission costs at least 50lbs. If you can do without either, the T5 is certainly the way to go.
Ford 5.0 into an M3
lampredi7
Building: Dutton 7 lampredi
Post by lampredi7 »
Engine weights in lb with manifolds and all accessotries no transaxles
GM LS V8 500 lb with accessories
Fiat Lancia 2.0 Lampredi twin cam 4 cyl. 272 lb
Audi 1.8 20vt 4 cyl. 280 lb
Nissan sr20 det 338 lb
Mitsubishi 4g63 4 cyl turbo 350 lb
VW 2.0 4 cyl aba 230 lb
VW Audi vr6 400
miata 1.8 290 lb
Ford 1600 Kent OHV 260 lb
Ford 2.0 Pinto SOHC L4 320 lb
Ford 2.3 L4 Turbo 380 lb
Ford/SAAB V4 230
Ford Zetec 238 lb
Ford/Mazda Mondeo V6 225 lb
Ford 289/302 V8 460 lb
Honda Civic 1500 205
Honda 24V V6 491 lb
Honda B18B four 326
Volvo B20E 340
Jaguar 3.8 six 592 lb
Lotus 907 (Esprit) 275
Buick/Rover 215 V8 318 lb
Chevy Sprint 993cc L3 147 lb
Chevy Vega L4 285 lb
Chevy Corvair flat 6 300 lb
Dodge Viper V10 716
FIAT/Ferrari Dino V6 285
hayabusa 4 cyl 150 lb
judd v8 240 lb 4.0 lt 12,000 rpm 570 hp
Mazda rotary 10a 280 12a 348 13b 337 lb
subaru 4 cyl 300 lb na
Toyota 4A-GE four 340 lb
Porsche 914 2.0 lt. 4 cyl. 311 lb 1.8 277 lb
VW flat-4 air cooled 200 lb
vw 1600 aircooled type 1 250 lb
Porsche 356 1.5 210 lb
Porsche 911 6 cyl 325 air cooled
79 Vw rabbit 1.8 lt. 231 lb
Porsche boxster 3.6 6 cyl. 450
Porsche 944 2.5 lt. 4 cyl. 340 lb na turbo 366 lb
Porsche m96 3.2, 3.4 6 cyl 410 lb water cooled
Porsche engine weights:
kg / lbs models Source
182 kg 400 lb 2.4L E, S, RS 1972-73 Tech. Spec. book
183 kg 403 lb 2.4L T 1972-73 Tech. Spec. book
182 400 2.7L 1974 unknown
200 440 2.7L 1975-1977 Aichle - 911 Engines
1983 3.0 400 lb
190 419 78-83 930/09,19,10 78-81 78-81 & 82-83 Tech Spec. book
200 441 78-83 930/03-08,13-17 78-81 & 82-83 Tech Spec. book
190 462 3.0L 1980-82 Aichle - 911 Engines
190 418 3.0L SC w/ SSI & heat,w/o AC measured
219 483 84-87 930/20,26 84-87 Tech Spec. book
220 485 84-87 930/21,25 84-87 Tech Spec. book
219 482 3.2L 1987 - 1988 Aichle - 911 Engines
238 524 964 89-94 M64/01,02 ROW &US 964 Tech Spec. book
226 497 M64/03 RS 964 Tech Spec. book
275 605 M30/69 3.3L 964 Tech Spec. book
276 608 M64/50 3.6L 964 Tech Spec. book
232 510 M64/05-08 993 Tech Spec. book
221 487 M64/20 993RS v-ram w/o ZMS 993 Tech Spec. book
230 507 M64/20 993RS v-ram w/ ZMS 993 Tech Spec. book
410 lb m96 3.2, 3.4
Laminar
Post by Laminar »
lampredi7 wrote:Engine weights in lb with manifolds and all accessotries no transaxles
You've weighed these all yourself? Or this is just another one of those lists that gets copied and pasted over and over again all over the internet? What are "all accessories?" Does that include power steering? Alternator? A/C compressor? Air pump? Flywheel or flexplate? Clutch assembly?
Which one? Aluminum block or iron block?
Which one? The Pinto 2.3 or the Duratec 2.3?
Which one? The 2.5? The 3.0? The 3.5? The 3.7?
Iron or aluminum head? Again, with flexplate or flywheel? Serpentine or v-belt accessories?
Ford 5.0 into an M3
Laminar
Post by Laminar »
Another one in my "complete drivetrain" series.
2009 RX-8 Renesis. Complete with:
- Engine
- Clutch/flywheel/pp/slave cyl
- Transmission
- Alternator
- Air pump
- A/C compressor
- Starter
- Wiring harness
- Aluminum engine mount brackets
- Throttle body
- Header
Not included:
- Rubber engine mounts
- ECU
- Oil coolers
- Shifter
Fluids gravity drained but not necessarily bone dry
450lbs
Ford 5.0 into an M3
RichardSIA
Building: Dio Tipo
Post by RichardSIA »
I should weigh my Kent 1600 with Webers and headers.
Not the most powerful but certain to be light for an iron block and heads.
The pics above give me a head-ache with all the complexity hanging from the engine.
