CS3's projects
Here is where the build logs go for non-traditional build logs. Mid-engine, three wheelers, you name it. If it's not your typical Locost it goes here.
chetcpo
Building: positive attitude
Post by chetcpo »
Wow, thanks for the engine pics. That thing looks pristine.
Jawfish
Post by Jawfish »
Wow Rod,
That engine sure does look in good condition from your pics. Keep trhem comming :D
Are you going to paint the aluminium center section ?
Question about the Se7en... Anything special on the 4AGE-T50 combo in the Lotus frame to whatch out for ? Are using a Regular Lotus nose cone or a modified one ?
Thanks
Fred
cs3tcr
Post by cs3tcr »
Fred,
I'm going to leave the sills on the Eleven in natural aluminium, but paint the doors and scuttle.
On to the 4AG/T50 questions, i'm using a Lotus nose cone, which is slightly lower than a Caterham one. I wish i had a Cat one when building the car, that way the oil pan wouldnt hang so low. The T50 is shorter than the ford gearbox in respect to the shifter position. If you want the shifter in about the right spot, you have to push the gearbox as far back as you can in the frame. The farther back you go the smaller the pedal box gets. My pedal box just accomidates size 10 shoes.
Rod
Jawfish
Post by Jawfish »
That will definetlly look good...
Hmmm size 10 shoes... not good, I`m 10.5 but wide... will have to fugure something... Then again I had the same issue in the Locost.
Thanks Rod.
Fred
cs3tcr
Post by cs3tcr »
Spent today playing around with the cylinder head. Opened up the exhaust ports .075" and polished both the intake and exhaust ports.
Then made up the generator mount. Going to take it to work tomorrow and have it welded on, then the head is off to the machine shop to get a valve grind.
Also, last Thursday and this past weekend i rebuilt the gearbox, cut a notch for the starter bendix and made up the wiring loom for the car. Got the loom all taped up and relized that i didnt include a horn circuit. So, i'll make up a sub harness for the horn, now i just have to figure out where to put it.
I wish i had a photo of the 'box in bits, but i was way to frustrated to be using a camera.
cs3tcr
Post by cs3tcr »
Spent the last couple days having/making up the fittings that pass through the block to allow an oil filter. So today, i drilled through the block to fit them, then cleaned the block to start on rebuilding the motor. I got the crank back in, and installed the jackshaft and timing gears.
This week i'm hoping to get the cylinder head off to the machine shop to fit larger exhaust valves along with planing the head .040" and doing a valve grind. Plus, get the rods crack tested then balance the rods and pistons. Its now looking like i will be able to have the motor done by the middle of December, and maybe running by New Years.
killernoodle
Post by killernoodle »
Man, I LOVE exposed clean bits of machinery. Its like looking into the case of a fine swiss watch.
Miatav8,MstrASE,A&P,F
The glypt on the inside is a great idea. I haven't seen that in years!
Locost 5.0
Post by Locost 5.0 »
Keep the updates coming, they're great. You do awsome work.
Rod
and a 1963 Nova SS
Jawfish
Post by Jawfish »
Wow, I just love the engine old engines :D
Keep the pics comming, I can't get enough
Fred
Dave
Contact:
Post by Dave »
Impressive stuff. I love that engine - great classic look. All your projects are extremely impressive - thanks for the updates. 8)
cs3tcr
Post by cs3tcr »
Just noticed that its been over 2 months since i lasted posted an up date. So, here it goes....
Spent the last month and a bit trying to get the motor done, but kept running into set backs. First, i sent my cylinder head out for machining and 3 weeks later i got it back(should have been back within 1 week in my mind), so that delayed things. Then installed the head and check the valve clearances. Obviously had to order up a complete set, that took only a week (pretty quick i thought). But, i miss measured, one shim was out by .040", so i ordered another bunch (only needed one, but having a selection never hurts). The second batch took 3 weeks (damn postal service). During the delay with the shims, i started to get the rest of the motor ready, i bolted up the fly wheel, tried the transmission on the motor with everything installed, had to relieve part of the bellhousing to clear a bolt, and finally fitted up the oil feed line for the cam and attepted to fit the oil drain back from the head to the block. And thats where the next problem occurred. The starter wont clear the oil line fittings. So, now i'm waiting for a gear reduction starter which is supposed to fit, fingers crossed. Anyways here are some pics, i know the garage looks a mess.
In the last pic you can see the boss for the oil line and the gap between it and the standard Lucas starter.
sevenesqueron
CS#'s projects
Post by sevenesqueron »
Hi Rod,
Despite your setbacks this project has really moved along. It doesn't seem all that long ago that you were just getting going on it.
What army was still using units with 55 year old engines in them and how did you find it?
Ron
cs3tcr
Re: CS3's projects
Post by cs3tcr »
After two days of struggle, this has finally happened:
http://s212.photobucket.com/albums/cc171/HockeyRoddy/?action=view&current=MVI_0954.flv
Turns out that $0.60 of o-rings can make a motor not run. And yes i should have bolted it into the cradle, lol.
a.moore
Re: CS3's projects
Post by a.moore »
Happens to the best of us. Props on getting it running.
How much is left until you'll be driving?
