Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Help!!! I cannot do compound angles
PostPosted: Fri Nov 03, 2006 9:55 pm
El-Loco
I have been in the garage for 3 hours have made lots of cuts but cannot seem to get the measurement right I nee a step by step on how to measure and cut the LA and LB tubes. I cannot for some reason seem to get it right. I need an easy to understand explanation. not really math and theory just how to do it correctly.
Thanks
PostPosted: Sat Nov 04, 2006 12:40 am
cut one angle, turn tube on side measure other angle from the straight edge of the first cut... i don't know any other way to explain it. well you could get a compound miter saw and make life easier.
**Build diary**
PostPosted: Sat Nov 04, 2006 12:47 pm
Most people reach for the compound miter saw first but I found that marking the tube (with magic marker and a scribe) accurately, cutting close with a hack saw, and then using a 8" or larger disc sander to grind to the lines was not only faster but allowed me to creep up on the angle and test fit! I ended up with very tight weld joints :) I had a table used for aircraft fuselage fixturing so I know my frame was very straight and i still needed to "coax" them in to get frame dimensions right. It also is quick for putting the all important bevel on each tube for welding! :wink:
P.S. The trueness of your table is critical or you wont be able to go by the prints angle call-outs to begin with! :? Good luck!
Fletch.
PostPosted: Sat Nov 04, 2006 1:09 pm
That's one reason I don't think designing a Locost (or any tube-frame) car in CAD will work. There's just too much variation in each joint, movement due to welding distortion, and human error to assume it'll all fit perfectly. You always have to be on guard for goofs, not matter how accurate the metal's cut.
Book: Design your own mid-engine car using a FWD drivetrain, http://www.kimini.com/book_info/
PostPosted: Sat Nov 04, 2006 2:13 pm
El-Loco
it is not so much cutting the angles. I have a All kinds of saws it is getting the correct angles and lenghts. I am not doing something right with the setting up of the angles to cut. Can someone start with the LA tube and tell me what lenght to cut it and starting on 1 side tell me how to mark the tube and then how to do the other end my mind for some reason cannot seem to get it right. I think once I get it visualized in my head I will be able to do it.
And believe it or not I don't "usually" ride the short Yellow Bus:)
Thanks for the help
Randy
PostPosted: Sat Nov 04, 2006 3:00 pm
Those cuts were REALLY tough for me too......
It helps if you meassure out and build a gig.....like this.
(fom Chets build log about three pages deep)
Then just slowly take your time and cut them to fit (make them to fit)
Failing that you could buy that peice for about 45 dollars from one of the linked distributors on the home page
Err it used to be northamericanlocost.com but the site is missing gone (did they go under?)
I'll keep an eye out for you!
To err is human...
I am more human than most.
PostPosted: Sat Nov 04, 2006 4:17 pm
I don't know if this will help but I just spent 10 minutes trying to draw something in Paint to help illustrate how I did it.
It's tough to explain, hopefully these will help you visualize it. I just marked the tubes and then cut each angle seperately with a hacksaw and a vice.
PostPosted: Sat Nov 04, 2006 4:32 pm
El-Loco
now thats what I needed I will try tomorrow
Thanks
Randy
That should be sticky'ed
PostPosted: Sun Nov 05, 2006 4:35 am
I cheated doing this, and it worked beautifully. I set the horizontal angle up for the cut , using my cheap horizontal band saw. Then I lifted the far end of the tube up (so it wasn't sitting flat on the bed of the band saw) using a piece of steel to prop it up to the correct angle. I first scribed the vertical displacement angle onto the steel with a scriber, and just lifted the tubing up until the scribe line was exactly at right angles to the saw bed, jammed a piece of steel tubing under it to keep it at this angle. Clamped the tube in place, made the cut. Perfect, first time!
Repeated this procedure for all the needed cuts, and didn't even need to massage any of the cuts with a grinder. Everything lined up better than I had hoped, with no need to grind, or fill with MIG. It may not be elegant, but it's results that matter...
:D :D :D
PostPosted: Sun Nov 05, 2006 12:23 pm
What zetec7 said. Plus, if you're using a cutoff saw, you can make a block that's the correct angle for one line (to hold the tube tilted vertically a la zetec7) and set the other angle with the miter function, or you can find cheap compound miter saws for wood, and they'll last a fair while using abrasive blades on steel. Only caveat is, if they have plastic angle graduations, they'll melt from the sparkstorm, and you won't be able to read them.
On the control arms; are you going with Book bushings, or rod ends? 'Cause if it's rod ends you'll want different angles than in the book.
Too many Locosts--BEC for sale $7500 at viewtopic.php?p=58282#58282
PostPosted: Mon Nov 06, 2006 5:16 pm
I made a tiered block setup as shown in one of the above posts, clamped the horizontal tubes on them, cut the vertical tubes close using the "block under one end while clamped at an angle in my chop saw" that Jack mentioned, then did a lot of grinding, fitting, grinding, fitting, etc. Took a while, but it worked for me.
One thing to be careful of, is that the outer edge of the vertical tubes needs to be at the correct angle if you want your suspension brackets to be at the correct angle without shimming. I didn't get mine quite right and had to shim the brackets before welding them. Seems to me if you use a tiered block setup, the outer edges should be perfectly vertical - 90 degrees to the table using a vertical square.
John
PostPosted: Sun Nov 12, 2006 3:21 am
Hi - Sorry to have come to this thread so late but have a look at my build diary no2 for a simple jig that worked really well for me.
If you aren't certain what length to cut the LA and LB just make them say 6mm longer then cut off to the right length with an angle grinder and thin blade once you have offered them up. The existing cut gives an easy guide to the new cut.
Also note my comment about only tack welding in until you have finalised your wishbones.
http://www.Locostsa.co.za/BuildDiaries/ ... ary_02.htm
PostPosted: Sun Nov 12, 2006 9:18 am
The short answer is start long mark with a black magic marker and sand to fit. Below is the long answer of how I realy do this.
I like to start by getting a 4ft by 9ft tall x 1.75" sollid core commerical door They are very strong easy to drill thru or screw to no make temperary fixturing. Next I lay out the entire chassis on the table/door in 1" wide tape. Now all you have to do is work your way around the table cutting/grinding each tube to fit within about 1/32" Tacking and clamping blocking each one as you go around. Any pair of tubes that will be later intersected by a cross tube needs to be welded in the corner at this point as once the cross tube is welded is, you wont be able to weld the inside of the intersection. THe other trick is always drill vent holes for every tube that will be eventually be closed at both ends. This will avoid building pressure in the tube later if you have to weld on the tube that will build pressure during welding and blow pressurized metal back in your face.
PostPosted: Fri Aug 31, 2007 6:20 pm
:D :D :D
This worked well for me. The angles are within 1º and the lengths are essentially identical and within 0.1". I actually never made a scribe mark at all - I just measured to the blade on the bandsaw.
PostPosted: Sat Sep 01, 2007 4:06 am
Hi - the jig in my build diary worked well for me:-
Translated by Xaphos © 2007, 2008, 2009 phpBB.fr
