It is currently September 24, 2022, 6:19 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: June 9, 2008, 8:09 pm
Just tubes with all braces, etc... no paneling. Particularly interested in those with real 4 point roll bars with cross brace.
My original Rotus frame is a real porker. Freaking 245 lbs!!!
Granted, about 40 lbs of that is probably additional tubing I added for replacing the lame 2 point, shorter than my head roll bar that was there.
It's a good thing I brought some additional horses to push it around.
I figured a good light frame is probably 150-170 lbs, but I have no idea.
On the other hand, she has withstood many years, many of them with V8's without any cracks or failures, so I guess that's good. Still depressed about the weight.
The distribution of the frame weight is roughly 61% on the back axle.
What are your weights?
PostPosted: June 9, 2008, 8:33 pm
I'm almost sure this exact thread was here within the last six months.
Anyhow, my mid-engine Mini's bare chassis is 200lbs.
PostPosted: June 9, 2008, 9:08 pm
I searched for frame weight and didn't see it. Oh well.
PostPosted: June 9, 2008, 9:29 pm
My chassis came in at this in kilos, thats 240lbs but I would rather be safe than sorry
and looks like this with full cage and all brackets
you can check my build diary here http://www.oz-clubbies.com/forums/index ... owforum=13
and look under onetrackwonder racing locost cheers greg
PostPosted: June 9, 2008, 9:41 pm
Including my 30lb 16g steel floor and 16g panelling on the footwells etc. But minus the rollbar. It's probably nearly a wash.
PostPosted: June 9, 2008, 11:17 pm
ontrack, you have a more substiantial roll structure than I do.
thanks for the feedback guys... my chassis is still on the heavy side, but maybe not by as much as I thought.
PostPosted: June 10, 2008, 1:28 am
Just finished mine, all be it, without any rollbars yet, and I'm not racing it.
But it came in at 145 lbs. I can see where a full roll cage would weigh at least 100 lbs extra. So 240 is probably pretty good.
Wayne
 Post subject: Frame Wt
PostPosted: June 10, 2008, 7:38 am
Bare frame without the top engine bay diagonal tube 78lbs
Add floor pan, front lower fire walls and both kick up areas next to the rear suspension points, using .053" stock added another 73 lbs.
Painted assembly 154lbs. again W/O top engine bay tube.
Dave W
PostPosted: June 10, 2008, 8:12 am
My basic chassis was 123 lbs, but that was without any of the center tunnel tubing installed and missing some of the other bracing. Also, my chassis had no roll bar (yet). I would not be surprised to see over 225-250 lbs, complete.
Jack Collins
PostPosted: June 10, 2008, 8:23 am
Quote:It's a good thing I brought some additional horses to push it around.
I figured a good light frame is probably 150-170 lbs, but I have no idea. (quote)
IMHO you are not asking the right question. Between a BEC builder to another one who builds a V8 Viento (luego) you should get a slew of varied answers and for good reasons. If you take a book chassis (Ford escort) and modify it to live up to the stress of supporting a 351 V8 you should end up with large differences.
Also: the bird cage is not the most critical components as far as weight is concerned.
Hope this is of some use to you.
Philippe.
PostPosted: June 10, 2008, 9:52 am
Philippe.
Yes, I agree, a BEC frame will not need to live with the stresses of a V8.
The difference between a 4 banger car frame and one that can handle a light V8 will be pretty minor though.
Anyhow, I was looking for a ballpark.
PostPosted: June 10, 2008, 1:55 pm
quote:Yes, I agree, a BEC frame will not need to live with the stresses of a V8.
The difference between a 4 banger car frame and one that can handle a light V8 will be pretty minor though. quote
Response
I would double check that one too.
What I have read is that flexing moments induced by a V8 exceed a 4 cyl's. The two factors at play being engine/transmission weight and torque. The subject is covered in various studies to be found in the Clubman resource site. Specific frame modifications have been formally required, in Australia for instance with respect to large engined Locosts. As an illustration the Australian racing 5.0 V8 Elfin weighs over 1900 lbs.
Good luck.
PostPosted: June 10, 2008, 5:05 pm
-the man.
This seems as good a place as any for this question. My steel supplier here in Tulsa doesn't stock .095 or 13 gauge tube. I just bought 100 feet of .083 or 14 gauge for my build table. I'll have a bit let over. They stock 12 gauge (0.108) or something like that. I know builders have used the 14 gauge....has anyone experirnced any problems? The 12 gauge would add about 10 pounds per 100 feet of tubing. I don't consider that an excessive amount but I'm the worlds worst at over building everything. I am seriously trying to uphold the Seven concept of sveltness.
RacerDan
+442 Chevy 2.8
PostPosted: June 10, 2008, 5:42 pm
For a BEC or 4-cyl, you'll be fine.
PostPosted: June 10, 2008, 6:06 pm
I was under the impression "everyone" used 16ga. :?
cron
