Kinetic Research wrote:
Glad to see the beer fridge is in a very handy to reach spot, the tinnies won't even get a chance to warm up, you can reach them from the drivers seat. Looking good, get cracking.
The most important tool in the garage
Thanks mate!
This weekend I managed to get some garage time! First up I rewired the foot pedal from my old TIG welder to suit the Unimig, using the spare plug supplied with the machine and a $2.50 10k pot.
I almost just bought the unimig pedal but saving $300 for an hour of work was well worth it.
Next up I added a bus bar in the CNC cabinet for all the Earth connections and wired them to the machine - one to each moving axis and one to the frame of the machine.
Finally I had some spare time to work on the hot rod so I started on the upper radiator mounts.
These cups will have a ~25mm hole bored in them in the lathe so they accept the rubber bushes on top of the radiator.
Then I plan on adding some angle to bolt them to the grill support, and then run a threaded rod down to the lower radiator mount bracket, so they can be clamped down securely
Hopefully sometime this week I'll get a chance to pickup the steel and stainless needed for the turbo manifolds and the front guards/bonnet/scuttle structure, which will make it look even more like a proper functioning vehicle!
